R50/53 Adjustable LCA's a must for coils?
Old Feb 1, 2013 | 05:30 AM
Hochspannung's Avatar
Hochspannung
I'm probably picking up a used set up Megan racing coilovers with about 10000 km on them for my R53
Is having adjustable LCA's a must or will I be fine without them?
Ill just have more rear camber the lower I go?
Also will Megan's rub with stock 16 inch cooper s wheels ?
Old Feb 1, 2013 | 10:14 AM
cmt52663's Avatar
cmt52663
Yes the lower you go the more negative camber you will have, and so if you intend to drop more than an inch the LCA is probably a good idea.
Someone with Megan experience will no doubt help with your second inquiry...
Cheers,
Charlie
Old Feb 1, 2013 | 01:06 PM
marantz2010's Avatar
marantz2010
I just had a new set of Megan's installed on my R53 last Friday. Out of the box, the settings for height were perfect for what I wanted, which ended up being probably around a 0.75"-1.00" overall drop. The rear camber is ever so slightly at a larger angle than stock. I would envision the wheel wear to not be anymore than stock...
ALTHOUGH I should mention that I now take corners fast and hard because of the coilovers I had installed (and I also had a 22mm rear sway bar done at the same time). I could see extra wheel wear happening sooner because of my driving habits.
Hope that helps!
Old Feb 1, 2013 | 02:27 PM
Hochspannung
Hope that helps!
you didn't need spacers at all? what wheels do you have on. I have those 16inch honeycomb style ones.. not the 17 inch s lites
Old Feb 1, 2013 | 07:09 PM
Joe Ojeda's Avatar
Joe Ojeda
If your going to install the megans and only do street driving i wouldnt worry to much about adjustable arms. I have the megans installed, lowered about an inch.. Not sure how much neg i have in the rear but its not to bad.
Old Feb 1, 2013 | 08:45 PM
marantz2010
It doesn't look great right now, because the wheels are so inset from the fender. I should probably get spacers for my 17" s-lites but I'd rather just save up for better rims
Old Feb 2, 2013 | 10:09 AM
Hochspannung
Ok but currently you have no spacers and your tires clear the springs ?
Old Feb 2, 2013 | 10:13 AM
marantz2010
I guess I am confused. The tires clear the springs--didn't think it would have been an issue either.
Old Feb 2, 2013 | 01:35 PM
Hochspannung
I've read on forums, probably on here, that when you install megan's that the wheels have problems clearing the coils (springs) without like a 5mm spacer up front.
I just don't want to pick up these coils, drive to my buddy's shop 80km away to have him install them; then get stuck there because the wheels don't clear the springs without spacers.
It seems as if you didnt have that problem with the S-lites. I wonder if its the same with the honeycomb 16" wheels
anyone know the offset of both of those wheels?
Old Feb 2, 2013 | 04:02 PM
minsanity's Avatar
minsanity
But S Lites just look so right on lowered MINIs!
Keet
Suspension
Aug 30, 2016 03:46 PM
minimofo
Dec 26, 2015 12:03 PM
gnhovis
Dec 14, 2015 05:31 PM
Emnotek
Sep 29, 2015 07:37 AM
gnhovis
Sep 28, 2015 06:28 AM
