R50/53 Heat wont get hot anymore
Old Jan 5, 2013 | 01:00 PM
niquemarshall's Avatar
niquemarshall
Recently I've noticed this winter that my heat really doesn't kick in like it used to. When I first got the car, it worked good, and now this year it's gotten to the point where it blows cool when it's below 29 degrees... I've topped off the coolant with the BMW brand because it was low at first, and days later its still blowing cool... Sometimes it'll warm up but not very often. Any advice? Thanks
Old Jan 5, 2013 | 01:17 PM
Capt_bj's Avatar
Capt_bj
you're in Florida! You don't need heat!
How low did the coolant get? You might have an air bubble preventing flow to the heater lines. You might want to find a MINI savvy mechanic and have them bleed the system. GEN1 S is kinda tuff to bleed properly.
You might find a local owner with the expertise by a) identifying your town and/or b) checking http://www.sunshineminis.org/forums/index.php?style=2
Old Jan 5, 2013 | 01:25 PM
ZippyNH's Avatar
ZippyNH
You added coolant, but was it ever changed?
the heater core might be plugged.....rust, etc bulids up in a coolant system when the fluid is not changed regularly, and tge lowest point in thw systen, with the narrowest tubes/passages is the heater core....
Might be able to flush it, but many suggest new. Check the engine temp with a scanguage, etc to check for a stuck thermosts first, and mayve bleed it just incase you have an airbubble.
Old Jan 5, 2013 | 02:19 PM
niquemarshall
Yes it was fully flushed around thanksgiving time, heat worked and all of a sudden stopped working like last week
Old Jan 5, 2013 | 02:21 PM
niquemarshall
Lol I'm in sc right now, last night it got down to like 25 and it sucked driving all the way home with no heat that feels like Ac
Old Jan 5, 2013 | 02:23 PM
niquemarshall
Well the reservoir leaks sometimes, but recently it's been holding, the lowest it got was to where the reservoir was empty, but that was a while ago.
Old Jan 5, 2013 | 02:29 PM
Capt_bj's Avatar
Capt_bj
who flushed it?
I'm still guessing it was improperly bled
did they know there are 2 coolant bleed points on the top end of the GEN1 S cooling system?
btw - GEN1 S colant res' - ever been replaced? They only last about 4 years then the seam splits and they leak.
this one is leaking from the back side - the side against the firewall. It was the second one I'd put in this car.
Old Jan 5, 2013 | 02:36 PM
niquemarshall
who flushed it?
Here is my reservoir.. And I had it done at a shop. Yes I would imagine so, as I could see that the points were opened when I first got the car back from him... I could see where they had been taken off
wayner's Avatar
wayner
I have exactly the same symptoms...but am in Canada and freezing.
I'll be watching to see what you find out.
(2008 clubman - non S)
Old Jan 5, 2013 | 02:41 PM
Capt_bj's Avatar
Capt_bj
I dunno if it the source of your problem
but IMO those tanks are toasted and need to be replaced.
and THEN the system properly bled
Old Jan 5, 2013 | 03:29 PM
niquemarshall
It's the heater core
Old Jan 5, 2013 | 05:03 PM
jhiggs26's Avatar
jhiggs26
Your replaced tank looks like it's leaking again. Wipe the tank seam down and the whole thing then check it after a heat cycle. Your power steering bracket is missing a M6 nyloc nut/washer too.
Jeremy
Old Jan 5, 2013 | 05:16 PM
Cone Assassin's Avatar
Cone Assassin
It is also possible the thermostat is stuck open. Check the upper radiator hose when the car is at operating temp. It should just about be too hot to touch if everything is working properly. If you can comfortably grip it, I would go with that first, before diagnosing it as a heater core.
Let us know what you find.
Also another point - If you ever had green coolant mixed with factory, that can cause the coolant to turn into a jelly and block everything. Even when doing a coolant flush, this can stay behind and cause your heater core to be blocked. Just a thought, but I would check the temp on the hoses first.
Old Jan 5, 2013 | 05:36 PM
niquemarshall
Jeremy
Lol that's the stock bottle at 101k... What nut are you talking about?
Old Jan 5, 2013 | 05:38 PM
niquemarshall
OH! That nut! There's a funny story behind that thing being missing lol
Old Jan 5, 2013 | 05:42 PM
jhiggs26's Avatar
jhiggs26
101K that's pretty good then! Did you replace your heater core then? I'm dreading when I have to do that.
Jeremy
niquemarshall
Yup. Pretty sure that's what happened. In feb 2011 I bought the car with orange coolant in it. Eventually an oil leak developed from the o rings on the oil cooler, and it turned out that there was play doh like substance in all nearly all the lines. That's been fixed, and the heat worked, albeit not as hot as when I first got it... And it worked up until like Christmas Eve, when it blew cool... Every now and then it blows warm, but only if you turn it off and wait like 5 minutes.
niquemarshall
Ill also check that hose
Old Jan 5, 2013 | 05:43 PM
niquemarshall
Jeremy
Heater core hasn't been replaced, but from what I heard it is rather easy
Old Jan 7, 2013 | 04:44 AM
niquemarshall
Ok so I felt the hose, sure enough I can comfortably grab it after driving it about 15 minutes. Does this mean the thermostat is done, or could the radiator be blocked as well?
Old Jan 7, 2013 | 11:18 AM
fcminicoopers's Avatar
fcminicoopers
You might wanna check this out http://www.parts4euro.com/DCShop/ind...fd50ae3b941552
Old Jan 22, 2013 | 05:35 PM
wayner's Avatar
wayner
Mine turned out to be a thermostat. It's a 2008 with 65,00 kms.
Old Jan 22, 2013 | 07:09 PM
ZippyNH's Avatar
ZippyNH
Good to hear yours is working again, but just so you realize, your car, according to your signature, a 2008 clubman, is a VERY different car...different motor, etc, so posts in the gen2 section might be more useful for you.
Old Jan 23, 2013 | 07:13 AM
niquemarshall
Yea I think I'm going to check or replace my thermostat first and check coolant hoses for possible blockage
Old Feb 17, 2013 | 06:59 PM
niquemarshall
Hey guys quick question.
Are the hoses to the heater core, the interior hoses, supposed to be hot when the heat is on? I felt mine, the inside ones behind the kick panel, they felt like hard lines and they weren't hot...
Any answers?
