R50/53 Brake lights not working
Old Nov 11, 2012 | 10:19 AM
joshp912's Avatar
joshp912
I checked ALL the fuses JIC and they're good. The bulb's were good as well and screwed in properly.
Is there a brake switch on this car....2004 R53?
Also blinker's are not working either.
Old Nov 11, 2012 | 11:30 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The actual switch is on the brake pedal lever under the dash. Such switches do occasionally go bad. They are not hard to replace, I've done a few at work on some Kia vehicles.
Did the brake lights and blinkers stop working at the exact same time? They are usually separate circuits. Do the hazard flashers work at all?
Old Nov 11, 2012 | 01:26 PM
ZippyNH's Avatar
ZippyNH
Make sure it is the right brake light bulbs.....a similar dual filiant bulb will fit, but not work.
if the blinkers are out, and brake lights are both out...sounds like it could be the bcm...but still check fuses and bulbs first....
Old Nov 12, 2012 | 05:13 PM
joshp912's Avatar
joshp912
So the hazards do not work and all the fuses are good to go....and ALSO the "trunk/hood is open" sign won't go away when both are shut. I put the right replacement bulbs in.
Should I try doing the ECM reset?
Old Nov 12, 2012 | 05:28 PM
joshp912's Avatar
joshp912
Ok I just did the ECM reset, didn't crank the car up but turned the key over and am still having no brake lights or turn signals.
Old Dec 8, 2012 | 03:37 PM
R53Erf's Avatar
R53Erf
I had the same issue with my 02' R53 and found out what it is. When the tail light is removed there is a circuit board in there. That circuit board wasn't making good contact/was a faulty circuit board which had to be replaced. Hope this helps. It may or may not be the problem in your case, but at least it's something else you can rule out.
Old Dec 8, 2012 | 09:07 PM
joshp912's Avatar
joshp912
R53Erf - Where did you get the circuit board replacement from and do perhaps remember how much it cost?
THANKS !
stellaherself
Aug 14, 2015 05:28 AM
Terry Gallentine
Aug 11, 2015 03:31 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
