R50/53 2006 Used MCS: Am I Mushrooming?
Old Oct 20, 2012 | 04:44 PM
barchuleta's Avatar
barchuleta
I have been reading threads about the mushrooming issue on Mini Coopers. I bought this used but I do know that it has always had 16 inch run flats. During my initial inspection it doesn't look like there is mushrooming but one bolt is a few millimeters crooked. I would like to ave a second opinion, I plan on buying reinforcements.
Below are the image links
http://www.flickr.com/photos/barchul...7631815184469/
There is the possibility that I am being way to paranoid but I guess one can never be too careful. If necessary I can add more photos with more angles.
Thank you very much!
Old Oct 20, 2012 | 05:25 PM
barchuleta's Avatar
barchuleta
I just did a level test and both strut towers passed so I guess its all good, I will keep a close eye on them though. (I drive gently).
Old Oct 20, 2012 | 07:50 PM
Pure87's Avatar
Pure87
If you regularly drive in an area with really bad roads, you should probably invest in some strut tower defenders, sold by most Mini vendors. They can help prevent mushrooming and aren't a bad price. That will definitely be one of my next mods as i live in the land of the pothole.
Old Oct 20, 2012 | 08:44 PM
Kahnfucious's Avatar
Kahnfucious
Yeah just invest in the craven speed strut tower defenders or the m7 strut tower bar. It only takes one good hit to the suspension. You may drive carefully but you can't see everything coming (at night) behind someone...etc.
15 minute install and that's it. $130 ish is pretty cheap insurance. I installed mine on day 2 of ownership.
Old Oct 20, 2012 | 10:09 PM
Eric_Rowland's Avatar
Eric_Rowland
+1 Hit a HUGE pothole on the freeway near Flagstaff, AZ. Ouch.
Old Oct 20, 2012 | 10:27 PM
minsanity's Avatar
minsanity
I drive carefully & still had some slight mushrooming. As my passenger strut mounts cracked, switched them both w/ OEM, restored the shroomn flat, then put on the Cravens for peace of mind. Plates are totally worth it.
Old Oct 21, 2012 | 05:36 AM
daflake's Avatar
daflake
Your strut towers look fine but the others are right, you might want to invest in some plates for the tower. I use the M7 Strut bar and love it.
Old Oct 21, 2012 | 07:50 AM
barchuleta's Avatar
barchuleta
Yeah I have decided that I am going to start saving up so I can purchase plates and install them. I too live in a pot hole ridden zone of the city. Until can get the plated installed I will drive very carefully.
Do you recommend the Madness MINI Cooper S Strut Tower Reinforcement Plates or another brand of plates?
Old Oct 21, 2012 | 09:59 AM
daflake's Avatar
daflake
They are all about the same so the preference is yours.
newminijcw
Oct 21, 2015 02:37 PM
CooperSharp
Oct 12, 2015 09:21 AM
barthayes
Oct 1, 2015 05:22 PM
patsum
Sep 30, 2015 02:10 PM
rt808
Sep 29, 2015 03:15 PM
