R50/53 R53 Paddle Shifter Removal
Old Sep 20, 2012 | 08:35 PM
bahman's Avatar
bahman
Does anyone know how to remove the paddle shifters on steering wheel of '06 MCS automatic?
Any tip, info, picture, etc. would be much appreciated.
Old Sep 20, 2012 | 09:25 PM
miles_miles7's Avatar
miles_miles7
You have to remove the airbag and unscrew the bolts that holds the paddles.
Old Sep 20, 2012 | 09:33 PM
miles_miles7
as far as removing the airbag you have to feel for these soft spots behind the steering wheel located approximately at 11 and 1 o clock. once you find them poke a hole with a screw driver or similar. take the screw driver and shoved it in there gently and feel for a stop. once you get there push in some more and that will disengage the lock that holds the airbag and pull on the airbag. remember there are 2 of these locks (clip).
Old Sep 21, 2012 | 07:12 AM
bahman's Avatar
bahman
PAddle Shifte Removal
Thank you Miles_Miles7. Really appreciate the info.
Will try it his pm.
Old Sep 21, 2012 | 08:59 AM
Noonzio's Avatar
Noonzio
Once you get the airbag off its pretty straightforward
Old Sep 22, 2012 | 06:43 PM
miles_miles7
bahman,
where you able to remove your airbag?
Old Sep 22, 2012 | 08:50 PM
bahman's Avatar
bahman
Removing Paddle Shifters
Could not locate the soft spots at the back of this 3-spoke wheel. However, since the airbag had deployed, I was able to bend the metal plate that housed the airbag, get to the 3 Torx screw, and remove the plate. Once the backing plate was removed, all fell in place.
I was able to remove the switches on the stering wheel, the paddle shifters, adn teh stalks, no proble.
I really appreciate your help in guiding me.
Bahman
Melvinyip
Apr 17, 2020 09:28 AM
caiken
Aug 27, 2015 06:55 AM
ki7hy
Aug 12, 2015 07:07 PM
jcb-memphis
Aug 8, 2015 11:09 AM
