R50/53 GreekDrifter's R53
Old Apr 9, 2016 | 06:49 PM
  #501
GreekDrifter91's Avatar
GreekDrifter91
more parts showed up.
this TO bearing already looks way better than an OE part. from what i can remember lol
Old Apr 9, 2016 | 07:36 PM
  #502
Kahnfucious's Avatar
Kahnfucious
Wow Greek good stuff!!! I remember when you dropped the tranny last time - when are you dropping that subframe again??
Old Apr 9, 2016 | 07:38 PM
  #503
GreekDrifter91
Pretty soon. You may have missed the post, but i will be rebuilding the engine. I figured i would add a few things since everything will be out.
Old Apr 10, 2016 | 09:32 AM
  #504
Kahnfucious
Cool - gonna do anything custom on the bottom end or just get it back together again? Also - did you ever get a tune or just run the 380 CCs without any kind or remapping?
Old Apr 10, 2016 | 09:50 AM
  #505
GreekDrifter91
No just gonna replace what need replacing. Not looking to get huge power so dont need to build it up. Engine is stoute enough. No i never got tuned for the 380 injectors. Just run them as is. I will get tuned once engine back together and i have broken it in.
Old Apr 11, 2016 | 11:52 AM
  #506
Mine cracked and the wire came out of the top. 200K miles.
D2R ones here: OSRAM and heliolite 63126907495
https://www.ecstuning.com/Search/SiteSearch/63126907495/
Old Apr 13, 2016 | 02:57 PM
  #507
GreekDrifter91
box of little parts came in today. a timing chain kit.
Old Apr 21, 2016 | 01:16 PM
  #508
GreekDrifter91
few more things in the mail...
TSW front motor mount. Powerflex bushings for the front swaybar. and the belt tensioner
just a few things i didnt do the first time around. i actually need a new motor mount mines pretty shot. these three should compliment the rest of the poly front end.
Old Apr 23, 2016 | 07:22 PM
  #509
Kahnfucious
few more things in the mail... TSW front motor mount. Powerflex bushings for the front swaybar. and the belt tensioner just a few things i didnt do the first time around. i actually need a new motor mount mines pretty shot. these three should compliment the rest of the poly front end.
Don't give up on the TSW right away - it's very harsh at the beginning but give it maybe 500-1000 miles and it will mellow out.
Good luck with everything!!
Old May 3, 2016 | 03:41 PM
  #510
GreekDrifter91
NOW, for the Pièce De Résistance. i present a quaife LSD
actually got it last week but was busy. i also forgot to order bearings as well. so i placed an order just now for some diff bearings and races.
I planed to start ripping apart the car on monday but the weather has been awful all of a sudden. maybe tomorrow or thursday i can start.
Old May 7, 2016 | 04:39 PM
  #511
GreekDrifter91
well today was the nicest day we are gonna have for a while... there were light sprinkles and overcast all day. but made short work of the mini.... only need to pul the axles drop the subframe and pull the engine and trans out.
Then My first problem of the day.... now im gonna have to pull the threaded section out of the crash beam.
Then Problem of two. somehow, i guess a bolt backed out and these two were just dangling and the crank pulley was rubbing against them...
Thats it for today. ill pick this up again next week when we have good weather again, and i need to grab the engine crane from my brothers house.
Old May 7, 2016 | 04:59 PM
  #512
HaveATank's Avatar
HaveATank
Look like you have a leak from valcover or is that something else. I also worked on my car today. Put in the ATI Damper and preped the rear subframe and everything to come out. Thinking of doing it Monday. It going to be nice. Wanted yo do more but started the work around 3pm.
Old May 11, 2016 | 01:57 PM
  #513
GreekDrifter91
Differential bearings came in.
took pics of the part numbers and stuff so others might have a chance at finding them maybe at a cheaper price... they are timken bearings so should not be to hard to find with the part numbers.
Old May 11, 2016 | 02:09 PM
  #514
Thanks for posting up .
Looks like the skf one.
https://www.ecstuning.com/Search/Sit...892/ES2770056/
Old May 11, 2016 | 02:26 PM
  #515
GreekDrifter91
this set also comes with the outer races, i chose this set because of that, just in case i needed them.
Old May 14, 2016 | 04:24 PM
  #516
GreekDrifter91
AANNNNNDDDDDD its out, and i have had enough torture for one day.
Old May 18, 2016 | 06:34 PM
  #517
GreekDrifter91
Day 1 of tear down...
Had to deal with these... what a pain.
and the one bolt that would come out. drilled a smaller hole into the head of the bolt then used an internal extractor. i didnt have an external extracot small enough.
doesnt look good to me...
1 -> 2 -> 3 -> 4
Old May 18, 2016 | 06:42 PM
  #518
GreekDrifter91
Day 2
yup there is all the oil.... thats why i ddint like the looks of the plugs
Old May 18, 2016 | 06:48 PM
  #519
Da_Ghost's Avatar
Da_Ghost
That's a lot of carbon.
Old May 20, 2016 | 06:28 PM
  #520
GreekDrifter91
Day 3......
rods 1-4
caps 1-4
one side has oil stain from not being shot at by a oil squirter whilw the other side is clean.
crank bearings supports. pulley side to trans side
crank pulley side to trans side.
I think i may be lucky where it wont need a regrind or larger bearings. BUT i need to measure everything. time to break out the micrometers
Old Aug 12, 2016 | 12:33 PM
  #521
Stoker's Avatar
Stoker
So your rebuilding from the crank up, are you replacing the pistons for higher compression? new bigger valves? The Quaife looks very nice.
Old Aug 12, 2016 | 12:47 PM
  #522
GreekDrifter91
Yes i did, car is done. started first time. And drives nice. I have a tone of pics to upload and details to add just been very busy. And car is off the road again. Hard line for the rear breaks rusyed through and lost pressure. Waiting for new lines.
Old Aug 12, 2016 | 02:01 PM
  #523
Mini Mania's Avatar
R53
Great pix and detail. Thanks for posting. Recently picked up an R53 and if I ever need to do the same, I know where to look for pix.
Old Apr 11, 2018 | 03:55 PM
  #524
GreekDrifter91
WELL.... its been sometime idk 2 years?? and i kept putting off uploading the pics and so here we are lol. here are the rest of the pics. hope they help people.
Pics may or may not be in order... i guess we'll see. there is a lot of missing pictures too... i couldnt find them all.
Carbonite coating on SC pulley (belt has never slipped again)
BTW the steam coming off the inter cooler is the meth we poured on it and its boiling off.
Final numbers were 260whp 221wtrq estimated around 300hp at the crank. this is all done on the factory pre-facelift tune. i never got around to actually getting tuned but i have been told id be well over 300whp if i did.
the "rebuilt" unit i got grenaded so i decided to go electric water pump.
Old Apr 11, 2018 | 04:02 PM
  #525
Whine not Walnuts's Avatar
Whine not Walnuts
Wow.
Talk about bringing a thread back from the dead . . . . .
