R50/53 Need W11 engine rebuild specs please
Old Jan 31, 2012 | 12:32 PM
qpr60's Avatar
qpr60
Really appreciate it if someone can forward crank, rod and bore specs, specifically big end bore and crank/rod journal specs std and over/under sizes.
My engine re-builder is having problems running down this info through his usual sources.
Also I will need to repair the #4 rod journal as it is now egg-shaped. Interested in how and where you guys have repaired these. I'm in central California.
03 R53 spun bearing on #4
Cheers,
Old Feb 15, 2012 | 04:48 AM
jamez's Avatar
jamez
Wow, it sounds like the exact same thing as my 05 R53 (91,000 kms). I haven't confirmed the bearing but we're pretty sure.
At this point I can't help with the specs (I haven't gotten to the rebuild yet), but I did dig up the 2007 BMW TIS online and managed to get it working. I don't know if it has what you're looking for at this point but I'll be doing the rebuild in April/May.
I'm interested too if anyone has the answers.
Good Luck
Old May 11, 2012 | 05:26 AM
jamez's Avatar
jamez
Finally cracked the engine open and mine is spun on #1
https://vimeo.com/41840812
https://vimeo.com/41841095
Old May 11, 2012 | 07:59 AM
Martin Brenneke's Avatar
Martin Brenneke
Try the haynes manual as it usually has all the specs for each car .
flredmini
Sep 3, 2015 07:15 PM
danraabe
Aug 18, 2015 09:32 AM
Powershift
Aug 16, 2015 05:14 PM
skippermini
Aug 13, 2015 06:13 AM
calebmil
Aug 7, 2015 05:54 AM
