R50/53 Tips for changing out LCA bushings???
Old Feb 4, 2012 | 05:43 PM
  #51
imncrxtc's Avatar
imncrxtc
How much were the camber plates? Are they to eliminate the mushrooming? And do they replace the strut mounts?
Old Feb 25, 2014 | 04:28 PM
  #52
RA082324's Avatar
RA082324
subscribed. probably going to have to do mine in a month or two.
i can say right now, there is a pretty good chance im guna be attempting without dropping the subframe. hope it works out. lots of good info here.
and +1 on the plates, do they replace the strut mounts?
Old Feb 25, 2014 | 05:33 PM
  #53
shrevemini's Avatar
shrevemini
Top Answer: 1
Dropping the sub frame is not to bad. I did it by myself. I did purchase the press tool needed to remove the bushing. I rent the tool out for 60 dollars, plus a 70 deposit. It save you a ton of headache. I also have the ball joint tools also. Just remember if you drop the frame out. Go ahead and replace sway bar bushings and ball joints if you have a lot of miles on your mini.
Old Feb 25, 2014 | 05:35 PM
  #54
shrevemini's Avatar
shrevemini
Top Answer: 1
I did notice you are going to try with frame in. The tool I mentioned will let you do this.
Old Feb 26, 2014 | 05:00 AM
  #55
IQRaceworks's Avatar
IQRaceworks
There is no way you are going to save time by not dropping the subframe. It's such an easy thing to do....and getting to the ball joints without doing it may be possible, but I've never heard anyone say that it's fast, or easy.
Dropping your subframe is easy.
Old Feb 26, 2014 | 05:40 AM
  #56
RA082324's Avatar
RA082324
This is what has inspired me. I have all of the tools they are using.
Old Feb 26, 2014 | 07:24 AM
  #57
IQRaceworks
If you want to only change the LCA bushings...yes, with the right tools you can do it without dropping the subframe. If you want to change out the inner ball joints......you are better off to drop the subframe.
Just my opinion after doing the job a few weeks ago.
Old Feb 26, 2014 | 07:38 AM
  #58
RA082324's Avatar
RA082324
agreed. im just guna have to gwt under there and see what looks/feels worn. i know for sure the lca bushings are bad so thats my main priority. if i can afford to do other things i might. thanks for the input.
silence2-38554
Nov 12, 2015 09:39 AM
FLYM1N1
Aug 16, 2015 01:17 PM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
