R50/53 Front Strut Mount Plate - Rubber Cracked
Old Oct 1, 2011 | 09:59 PM
Bradg33's Avatar
Bradg33
I installed the Mini-Madness Strut Tower Reinforcement plates today and noticed that the rubber center of my front passenger side strut tower mount is cracked. I can't get a new part until at least Monday. Is the car reasonably safe to drive until then? I've attached a pic of what the crack looks like.
Old Oct 2, 2011 | 08:08 AM
msjulie33's Avatar
msjulie33
isn't that the metal part?
Old Oct 2, 2011 | 09:02 AM
Bradg33's Avatar
Bradg33
No, the center "ring" area is hard rubber.
Old Oct 2, 2011 | 09:28 AM
Eric_Rowland's Avatar
Eric_Rowland
Well, I figure you've been driving on it that way for a while, so it should last until Monday. Just don't try and Dukes of Hazzard tricks.
Old Oct 4, 2011 | 06:31 PM
WinnieMiniFW's Avatar
WinnieMiniFW
I'd drive her easy, like mentioned above. Be careful replacing that plate, I had to change mine out a few weeks ago. Make sure that the part is right, I ordered mine and it came in wrong because they used the picture for the strut mount for a bumper inside the strut. Not cool.
Old Oct 6, 2011 | 10:21 AM
Bradg33's Avatar
Bradg33
Plate successfully replaced. Kind of a bear to get the nut holding the mount to the strut. I may put together a write-up, given that the ones I found were pretty poor and didn't clearly explain what you need to do to get it off.
Old Oct 6, 2011 | 11:30 AM
Mynewt's Avatar
Mynewt
I had mine replaced this summer. How many miles are on your car? My right one started to crack at around 65k miles. I had new struts put in while he was in there.
Old Oct 6, 2011 | 02:04 PM
Bradg33's Avatar
Bradg33
60k. I may have cracked it myself when I was trying to bend the plate back into shape to fit the reinforcement plates I bought, but I didn't look that closely at it before I started hitting it with the hammer...
Old Oct 7, 2011 | 06:17 AM
msjulie33's Avatar
msjulie33
Yes please
Old Oct 20, 2011 | 04:00 PM
coopspeed's Avatar
coopspeed
Use a 13/16" spark plug wrench on the bolt and a open end wrench to turn it. The top of the strut itself has a 6mm allen. Use a long 6mm allen wrench through the 13/16" spark plug wrench.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Aug 7, 2015 05:56 AM
