R50/53 How do I remove...?
Old Apr 26, 2011 | 07:59 AM
bond007's Avatar
bond007
How do I remove...?
...the auxiliary gages (i.e. "BOOST" and "VOLTS") besides the tach.??? I have noticed thay are a bit crooked and want to re-install them aligned straight. Do they just pop-out of the bezel, or do I need to remove the whole "shebang" (tach, split the column cover halfs etc.) and pushe them from behind???
any help appreciated.
Old Apr 26, 2011 | 02:18 PM
hockeyman's Avatar
hockeyman
Are you referring to the after market gauges that hook up to the back of the tach on the steering column? I have the chrono package on my MCS and have not added any Boost or Volt.
I own the Bentley Manual and am happy to look up and display any pages that would be helpful to you.....
If you are into DIY with your MINI, $75 is the best investment you can make in Bentley Publishers.
Old Apr 26, 2011 | 05:19 PM
Vollgas's Avatar
Vollgas
If these are Craven pods, the gauges are held in place by a single set screw each.
Old Apr 27, 2011 | 12:01 PM
bond007's Avatar
bond007
Thanks for the replies, but I'm referring to the factory auxiliary gage kit. You could order your car with these from factory back in '05...
http://new.minimania.com/web/item/NMI7625/InvDetail.cfm
Old Apr 27, 2011 | 12:51 PM
Capt_bj's Avatar
Capt_bj
the minimania page you refeence contains a link to the original install instructions . . .
from those it appears the ga' just pressed into the mount. No set screw involved ... so unless someone decided to add some glue along the way . . .
Old Apr 27, 2011 | 09:25 PM
desmo's Avatar
desmo
Capt bj is right, the gages just press in. A little tug and the gages will pop out.
rosaymaan
Sep 20, 2014 05:19 PM
mmatarella
Tires, Wheels, & Brakes
Oct 12, 2006 09:54 AM
TonyB
Road Racing Discussion
Dec 30, 2005 08:02 AM
