R50/53 heater core valve
Old Jul 19, 2010 | 06:40 PM
zpnbyu's Avatar
zpnbyu
heater core valve
Where do I find the heater core valve on a 2005 mini? I need to bleed the cooling system and can't seem to find the valve on the heater core.
Old Jul 19, 2010 | 06:51 PM
Oxybluecoop's Avatar
Oxybluecoop
No heater core valve on a MINI. There are two vent valves one on the distributor pipe and one on the upper radiator hose.
Old Jul 19, 2010 | 10:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If it's not an S there is a bleed screw in the lines where they run between the battery box and P/S resevior. It's black plastic with a big phillips slot.
Old Jul 20, 2010 | 03:40 AM
zpnbyu's Avatar
zpnbyu
Thanks. My husband and I are not mechanics in any sense of the word and we are 100 miles from the nearest Mini dealership. We just came home from an 8300 mile trip and soon afterward, the fan started running overlong and last night the temp light came on. We discovered the coolant was low and refilled that, but the fan continued to run for about 5 minutes after the engine was shut off. A post on another website suggested bleeding the valves on the upper hose and heater core. We found the bleed screw on the upper hose and opened that and air did come out. The fan stopped running and the temp light has not come again. Am I correct in understanding that there is only one bleeder valve, and that is on the upper hose?
carole
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Nicefeet
Sep 24, 2015 06:53 PM
Redhotz
R55 :: Clubman Talk (2008+)
Sep 22, 2015 09:41 PM
