R50/53 I opened the coolant tank cap. Is that bad?
Old Jan 23, 2010 | 11:10 PM
MiniOwner2004's Avatar
MiniOwner2004
I opened the coolant tank cap when the car was cold. I did not hear any pressure being released. I noticed the res tank was almost empty. After I fill the reservoir tank, do I need to Re-pressurize the system?
Car is a 2004 Non-S
Old Jan 24, 2010 | 01:00 AM
911Fan's Avatar
911Fan
The pressure will increase automatically as the engine heats up when you drive the car. The pressure will drop back down as the engine cools down after your drive.
This assumes, obviously, that you've put the cap back on after filling the reservoir!
Old Jan 24, 2010 | 01:39 AM
markjenn's Avatar
markjenn
The Mini is rather odd in that the coolant tank is part of the pressurized system, not an unpresssurized overflow tank like on most systems. As such, you never want to remove it when the engine is hot, but it is fine after it cools down. You want the coolant to be between the min and max lines - there are some fins on the bottom of the tank that are at the min line so you want to keep it so those are submerged.
- Mark
Old Jan 24, 2010 | 07:06 AM
ZippyNH's Avatar
ZippyNH
you should be fine.....
One word of warning....use the same coolant you have in your car. Do not add any universal fluid....it does not meet specs for compatibility. The green, the orange, the yellow and the pink are all chemically different than what is in your car if it still has fluid from the factory/ dealer. BMW/mini fluid is blue, and is a hybrid technology fluid...zyerx g-05 I think is the aftermarket compatible stuff. But BMW/mini sells it undulated for about 18$ a gallon...just mix it with de-mileralized water...otherwise known as distilled water is recommend.
Since you only added a cup or so of water/coolant....you should be fine...you might want to get a jug for future use!!
Old Jan 24, 2010 | 09:20 AM
MiniOwner2004
Great, Thanks for the info. Seems to be running fine. I drove it to work and back (160 miles) round trip and no temp change.
Old Jan 24, 2010 | 06:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Since you have a Cooper and not an S the coolant tank is NOT pressured on your car, it's just an overflow tank. So your fine with opening it and topping it up. Don't worry.
Old Jan 24, 2010 | 07:37 PM
Justjones's Avatar
Justjones
Way,
Is it true you can remove the cap on the cooper s only if it is cool? Also are there any other no-no's when dealing with the cooling system in the cooper S?
Old Jan 24, 2010 | 08:23 PM
MiniOwner2004
I swear all I did was top off the coolant in the tank and in the fill port and now I seem to have a small leak some where, I noticed a small drip under the car today when I was replacing my spark plugs.
Old Jan 25, 2010 | 07:09 AM
ZippyNH's Avatar
ZippyNH
If you overfill the tank, it is possible that excess fluid will be vented.....cold it shpuld be at the full cold line, or hot, at the full hot line....above that and when it expands, it will drip out.
Also it is strongly recommended that you use a torque wrench to tighten down your spark plugs...and only install the plugs in a cold car.
Old Jan 25, 2010 | 06:58 PM
WayMotorWorks
Vendor
Originally Posted by Justjones
Way,
You should let it cool down before opening on an S, but if you let it cool a little and open it slowly to release the pressure that will work most the time. Other than that the only other NO NO is don't trust the coolant temp gauge. It will stay at the half mark until over 230 deg before it moves, by then the car is overheating. I suggest the ScangaugeII for using as a temp gauge.
Old Jan 27, 2010 | 12:06 AM
MiniOwner2004
Well I put the car on the lift and climbed around the engine bay, the coolant leak or drip seem to be coming from the thermostat area. The 3 bolts seem to be a little bit loose, So I tightened them up and we will see how the leak goes.
Old Jan 27, 2010 | 09:12 AM
ZippyNH's Avatar
ZippyNH
That is a very common spot to leak...a revised thermostat with an improved gasket is available. If you buy a new one...just be sure to get the newer one...they changed the color of the gasket...so you can tell the new stock from the old stock.
http://www.waymotorworks.com/thermos...t-r50-r53.html
Old Jan 27, 2010 | 07:19 PM
MiniOwner2004
Is this a good one to use?
http://www.autozone.com/autozone/cat...&parentId=63-0
Old Jan 27, 2010 | 07:44 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by MiniOwner2004
I personally would not use anything other than the OEM thermostat....I've heard a few folks say the universals don't fit due to the housing shape or that the gasket on the aftermarket must be notched to fit....IMO not worth the effort to save a couple buck...especially if you have to go through the hassle of doing it AGAIN!!
Old Jan 27, 2010 | 07:50 PM
ZippyNH's Avatar
ZippyNH
Car is a 2004 Non-S
I'm not trying to poke fun at you by saying this....but swapping out the thermostat might be over your head a bit....I'm sure you could do it...but it might be wise to get a pro to install it, or a good friend who knows what they are doing at the very least. When you are done, the system must have the air bled from it, and you must get the right type of antifreeze to refill it. None of it is especially difficult, but it sounds like you might need a buddy that can show you a few things about your car.
Old Jan 28, 2010 | 01:26 AM
MiniOwner2004
Hahah....Um what gave you the opinion that I don't know how to work on car?
I have a full shop with a 10K lift. Current projects are a complete fram off restoration 55 Chevy belair wagon, and a 1965 VW bug. I just finished a rebuild on my 96 jeep cherokee + installed a 4.5" rubicon superflex kit, and even painted the darn thing. Not to mention a whole plethora of other vehicles I have built. I just like comming here for advice and other opinons. "Mesure twice and cut once" I always say. But thanks for the vote of confidence..
Old Jan 29, 2010 | 11:32 AM
miniemee's Avatar
miniemee
I had a recent overheat issue on a 2007 mcs. The dealer replaced the thermostat housing which corrected the issue. They said a common problem.
Old Jan 29, 2010 | 01:00 PM
MiniOwner2004
Yeah soon as I get a chance, Ill order the new "updated" thermostat. Maybe Ill do a DIY thermostat replacement with photos. If it has not been already done.
Old Jan 29, 2010 | 01:46 PM
ZippyNH's Avatar
ZippyNH
Sounds like you know what you are doing no problem....just the line about do I need to " Re-pressurize the system" made me think you were a bit green...we see a lot of that around here!! Have fun...it is an easy job!!
Old Jan 29, 2010 | 06:24 PM
MiniOwner2004
Yeah I hear ya, Thanks take care!
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
ebowling
90
Aug 4, 2019 09:15 AM
HaveATank
Sep 4, 2015 08:04 AM
06R53
Aug 26, 2015 08:37 AM
