R50/53 2005 mini
Old Nov 29, 2009 | 06:58 PM
samtheman77's Avatar
samtheman77
2005 mini
have a new 2005 mini cooper with 60K miles. At 60mph there is front end shake that can be felt on both sides of the car, driver and passenger, there is no shaking when off the throttle so I doubt a motor mount. At the mechanic they changed inner and outer ball joints, speed sensors, , linkages in the front, new tires with proper inflation etc. If the CV joint boots are intact and joints are ok what else could this issue be? Tires are fine, wheel balancers are fine as well? I am stumped? The rotors and brakes also fine.
thanks in advance
Old Nov 29, 2009 | 08:02 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check your control arm bushings. They are known for wearing out, and if they are you can replace them with Powerflex bushings.
http://www.waymotorworks.com/product...4&cat=0&page=1
Old Nov 30, 2009 | 07:45 AM
CARdiac's Avatar
CARdiac
Mine does that as well, also under braking. I am currently in the process of replacing worn LCA bushings... I will let you know if this helps.
Old Dec 2, 2009 | 07:22 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
I would also check the wheel bearings. Jack up the front of the MINI and grab each front tire one at a time by the top and bottom and try to rock the tire in and out. If the tire if firm and there is no movement or "grinding noise" when you drive at low speed, then you should be able to rule that out.
iggi
18
Feb 9, 2026 01:00 AM
Wohnson89
Jun 10, 2020 04:53 AM
Toolman
Jan 20, 2016 06:50 AM
mdutton11
14
Oct 26, 2015 01:47 PM
tr3y003
Oct 22, 2015 10:48 AM
