I just changed my fuel filter in my 2005 Mini coop s. I went to start it after I followed the directions and it wont start? Any suggestions?
Did you crank it enough to allow the fuel pressure to build up and get the fuel to the injectors?
Make sure the fuel pump relay was put back on of you removed it. Also, double check for any wires that might not have been connected back. Sometimes it's things like this that are overlooked and will cause you a lot of frustration and time.
Quote:
I went over it again. Everything seems to be connected.Originally Posted by Fatherdeth
Quote:
You need more fuel in the tank. Drop another 5 gallons in the tank and try again.Originally Posted by lvcubs23
Almost a 1/4 tank
Quote:
You think? I guess in the morning I need to figure out how to put gas in my tank. Five trips to the gas station. I hope your right.Originally Posted by OXYBLUECOOP
You need more fuel in the tank. Drop another 5 gallons in the tank and try again.Oxy if you are correct I will buy you a beer. I thought there was enough gas in the tank, but it is acting like a car that has ran out of gas. I will let you know in the morning.
Functioning Lunatic
My tank was near empty when I changed my fuel filter. The car didn't start the first time, but then it cranked and was fine. Took about 2 weeks for the smell of gas to dissipate. It had sprayed all over the seat area when I did the job.
Moderator
I take it you are not smelling any fuel so the line must be attached properly. And I am trusting that you double and triple checked your work.
Maybe you have another issue....did you disconnect the battery before doing the filter change... ?
Check for a blown fuse(s)...fuel pump ect.
BTW: You have to re-pressurize the fuel system after this filter change.
Turn the ignition key to position 2 w/o starting the engine, then to off again. Do this about 5-8 times.
I will check for the fuse also. No I didnt disconnect the batter before. I did after to see if that would get it to start but no luck.Originally Posted by -=gRay rAvEn=-
I take it you are not smelling any fuel so the line must be attached properly. And I am trusting that you double and triple checked your work.Maybe you have another issue....did you disconnect the battery before doing the filter change... ?
I did the key positioning thing too.
Moderator
#1 rule with cars. When you mess with fuel stuff best to diconnect the battery Originally Posted by lvcubs23
I will check for the fuse also. No I didnt disconnect the batter before. I did after to see if that would get it to start but no luck.I did the key positioning thing too.
couuld be while disconnecting and reconnecting the system a fuse was blown.
Be sure your gas cap is on nice and tight. If it is try disconnecting the battery for a couple of minuites and reconnecting. Most of the time this will reset your computer.
Ronnie948
Ronnie948
Quote:
OXY YOU ARE THE MAN. Five gallons of fuel Johnny Cash started right up!Originally Posted by OXYBLUECOOP
You need more fuel in the tank. Drop another 5 gallons in the tank and try again.That's great, but why did you need to change the filter in the first place? The manual says they're good for the life of the car.
Moderator
????????? What ?????
Exactly what component in the fuel system prevented the starting of the car due to only having 1/4 tank ?
Sounds more like not enough fuel pressure in the system before attempting to start....instead of not having a full tank.
Quote:
Just hit 60k miles. I know it says life time filter but the one I took out was black as coal.Originally Posted by veggivet
