R50/53 Brake rotors
I think you want a T50 torx bit. I know it doesn't make a lot of sense but from my understanding a T50 fits into a M10 screw. And looking at my set, that looks to be the right size. Hopefully the people at the tool store or someone here can confrim that.
Thanks everyone. the local auto parts store has a T50.
Temperature this weeked in expected to be 80°, perfect weather for repairs and beers.
I have never had to replace a torx bolt on any of the cars I have ever worked on. Just make sure to soak the bolt well and let it sit for a while.
And don't over tighten them when putting them back on. You really don't even need them, they are only there to keep the rotor in place while you attach the wheels.
Good luck!
Good luck!
Also, a trick I learned to "wake up" a bolt is to insert the torx bit firmly into the bolt head (bit is off of the ratchet/breaker bar), then tap the bit once with a hammer or mallet. Obviously how hard you tap will be commensurate with the bolt size; it doesn't take much force. This will "wake up" the bolt plus tends to set the bit into the head if there is rust or gunk in there, gumming it up.
Excellent advice from everyone. I have been studying my Haynes manual very carefully. Purchased the T50 torx bit, 18" breaker bar and the torque wrench is ready to go. Also bought new pads and I'm going to reuse the brake sensors. I'll let everyone know how I make out.
Thanks again for all the support.
Well, I hope it worked for you... My mechanically inclined co-worker and I went through three Torx 50 bits and three of the heads sheared off with a compressor driven gun... it was not a good day to say the least. Only one backed out after much effort.
Just use anti-seize compound on the new Torx screws when you install them so the next time they come off they come off easily.
Ok everyone here is an update on my rotor/brake pad change out - Everything went very smooth. No issues with the torx screw, each one backed out nicely. Removed/installed the caliper bracket easily. I was very surprised how easy it really was. Reading the Hayes manual along with your suggestions I changed out all 4 wheels in 3.5hrs. Lil greenie runs very nicely, no more steering wheel wobble when applying the brakes.
I do have another question - is there a break in period? The brakes stop the car nicely, but it seems to take a bit longer than the original brake/rotor setup.
The original rotors did need to be changed, when I compared them to the new ones, the original rotors were noticeably thinner.
Thanks again everyone for all your suggestions and inputs.
You guys ROCK! Happy Motoring!!!
you either need to 'bed the brakes' or 'drive carefully for the first 200 miles'
yes, there is a break in. bedding does it FAST but things can go wrong. drive carefully lets the natural use of the brakes wear thru the various coatings on the surfaces. some pads even include a special 'break in coating' ... even your owner's manual included this advice (drive carefully for a while) for your new car & its brakes
What is bedding?
molala
Oct 2, 2015 01:53 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
