R50/53 How can I tell it's got H/K?
My 05 MCS has Harmon Kardon lettering around the edge of the speaker covers on both doors. Also you can check the right side of the boot. It will have a cover that you open and a amp should be there.
Hahahah! Ya totally! But when you just dont know, sometimes you got to ask!
Don't forget - pushing the little musical note on the left side of the head unit on the H/K will bring up several more audio tailoring options than the simple bass/treble/balance/fader... just in case the door panel speaker surrounds were removed for some crazy reason (though I can't imagine why).
I don't know if the Canadian options are different than those for us Yanks, though.
The speaker surrounds are the biggest giveaway...
Good luck with the new car!
There is also a quick trick to see if the head unit is also a H/K. Although I have never seen a Cooper with H/K speakers and a non-H/K head, but I guess it is possible. Just click the button with the music note on it which cycles it through bass/trebble/fade, one of the last options is "MINI H/K" which means it is the H/K head also.
To be honest though, if the speakers say it, you should be all good.
You're correct - there were three different CD head units used in the 1st-gen cars, (two made by Alpine and one made by Siemens), but which one you have depends only on when your car was built, and not on which audio option you have (Boost or H/K).
Didn't the H/K head unit not send the same signals as the Boost head unit? I thought the H/K was designed to transmit signals to the H/K amplifier where volume and tone controls where handled while the boost had internal amplification and EQ abilities.
You're correct that with the H/K system, the output from the head unit is constant, and the actual volume/tone control/equalization is performed inside the H/K amp. But that same head unit would also work in a Boost system without the external amp. The head unit knows what kind of system it's installed in, and modifies its behavior accordingly.
Unfortunately, my H/K head unit is unable to display ID3 tags from either MP3 CDs or iPod sources. My car was built in February 2005 and I was hoping to have this feature supported by the head unit's firmware. By the way, my H/U is an Alpine radio.
The 2006s (especially later builds) have the Siemens head units and my understanding is that those can display ID3 tags from MP3 CDs.
No other complaints from my H/K setup. I really love it and I think it blows right out of the water either factory stereo system currently offered in the R56.
No ID3 tags on my Nov/05 build.
And to the OP, if you see a car that has the "regular" grilles but with a horizontal label that says "Digital Power Sound Modul" on it, you've hit the jackpot.
the speaker grills are the easy give away.
But, for some reason i remember hearing someone bought a mini, unknowing of the options equipped, and turned out to have the H/K system even though the previous owner changed the grills to the standard ones.
I might be making that up though. haha
None of the 1st-gen stereos would display ID3 tag information in stock form, but all of the ones from March 2005 onward (like yours) support the feature if you use an external iPod interface like the DICE Silverline or similar kits.
I don't know if there's any way to get the ID3 tags to display if you burn an MP3 disc and stick it in the head unit, though.
Seems to be much more impressive than the H/K system but also expensive
patsum
Oct 1, 2015 06:33 AM
Navigation & Audio help identifying a couple wires
yashmack
Aug 15, 2015 03:11 PM
