R50/53 R53 JCW Ceramic Rotors
Old Dec 10, 2008 | 05:38 AM
  #26
PGT's Avatar
PGT
stock rotors work just fine for the JCW kit. I've got a spare set sitting in the garage.
Old Dec 10, 2008 | 05:50 AM
  #27
Marwan's Avatar
Marwan
I'm looking for the plain, not slotted/drilled. If you have those, how much would you sell them for?
Old Dec 10, 2008 | 06:02 AM
  #28
minimarks's Avatar
minimarks
Originally Posted by Marwan
obusing? Can you be more clear please?
Abusing...track day! Last Phil Wicks I went to I was running OEM R53 brakes with Carbotech pads and as Blimey can attest to we recorded rotor temps of 880 degrees after a 30 minute session...HOT! Don't have that brake set up anymore.... If your going to run them hard get something strong and reliable. Just my 2 cents.
Old Dec 10, 2008 | 06:08 AM
  #29
Marwan's Avatar
Marwan
I'm killing myself to go aftermarket but I can not find anything good. Brembo do not have any rotors for the 07 or the 06 JCW, DBA also do not have for my 06 JCW. Where shall I go?
Old Dec 10, 2008 | 06:17 AM
  #30
Marwan's Avatar
Marwan
Here are the measurements for the JCW rotors:
Diameter=294
Original Height=44
Original Thickness=22
Min. Thickness=20.6
Centrel Hole Diameter=64
No. of Bolt Holes4
Old Dec 10, 2008 | 06:26 AM
  #31
minimarks's Avatar
minimarks
When the JCW rotors wear out, if I don't just get another set of those...Probably go with a DBA rotor. The rotors on the R56 are the same size as the JCW kit rotors... If your car was manufactured before 5/06 you might need to address the lug size but I'm not sure...PGT probably knows.
Old Dec 10, 2008 | 06:43 AM
  #32
PGT's Avatar
PGT
yes, that's what I have. They have perhaps 6k miles on them (previous owner swapped to the drilled ones for looks) $75 + shipping
Old Dec 10, 2008 | 06:45 AM
  #33
PGT's Avatar
PGT
the 14mm hole on the R56 rotor is no issue if you're using them on a JCW equipped 12mm car. The bolts are 60 degree conical taper - this centers the wheel along with the lip on the hub face.
Old Dec 10, 2008 | 07:37 AM
  #34
Marwan's Avatar
Marwan
Used? Sorry I'll have to get new ones because used rotors squeel badly on Carbotechs
Old Dec 10, 2008 | 07:38 AM
  #35
PGT's Avatar
PGT
if that's the case, you're not bedding them in properly
Old Dec 10, 2008 | 07:45 AM
  #36
Marwan's Avatar
Marwan
Yeah, you are 50% right. Also, I got the drilled/slotted JCW rotors which are impossible to resurface and they were used when I got my AX6s.
By the way, I'm the Middle East dealer for Carbotech brakes,
Old Dec 10, 2008 | 08:00 AM
  #37
Marwan's Avatar
Marwan
www.auto-works.cc
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
rckrzy1
Aug 11, 2015 06:06 PM
