R50/53 Brown stuff?
Old Nov 24, 2008 | 06:10 PM
dandennis123's Avatar
dandennis123
Brown stuff?
brown stuff is pouring out of my coolant resivor, but its not over heating wut could the problem be? i smashed the top of my inercooler could that be it?
Old Nov 24, 2008 | 07:02 PM
robbybee's Avatar
robbybee
Sounds like it might be time to call The Exorcist!!
I have NO idea. You are getting pressure into your cooling system somehow. How did you smash your intercooler?
Old Nov 24, 2008 | 07:09 PM
dandennis123
i left a light bulb box on it n closed the hood lol but i was told it was the head gasket. never have work done by dinan motor sports!!!!
Old Nov 24, 2008 | 07:13 PM
robbybee's Avatar
robbybee
A bad head gasket will do it! Pressure from one of the cylinders leaks into the cooling system and forces all of the coolant out. But if it's brown, you might want to change your coolant more often.
Old Nov 24, 2008 | 07:19 PM
dandennis123
it was just changed by dinan 2months ago when i had some problems with the work they did
Old Nov 24, 2008 | 07:24 PM
robbybee's Avatar
robbybee
WOW! A little bit of fuel and maybe oil could get into the cooling system but not enough to turn it brown, I wouldn't think. The other possibility is that the block is cracked - I hope not for your sake - and is allowing engine oil to contaminate the coolant.
Do you have water in the crank case? If so, that could be a clue as to what will need attention.
In any case, that sucks!
Old Nov 24, 2008 | 08:36 PM
AutoXCooper.com's Avatar
AutoXCooper.com
what color is the oil on the dip stick?
Old Nov 24, 2008 | 10:48 PM
dandennis123
their isnt any
Old Nov 24, 2008 | 11:03 PM
Eric_Rowland's Avatar
Eric_Rowland
FWIW, my old CRX says that a leaky head gasket can let enough oil get into the coolant to create a lovely (not) light brown sludge in the radiator. Continued on for months, with no transfer of coolant into the oil.
Old Nov 25, 2008 | 05:34 AM
thulchatt's Avatar
thulchatt
Not sure what is causing the overflow but MINI coolant does turn brown with age. Could someone have overfilled it when the car was cold?
Old Nov 25, 2008 | 07:00 AM
AutoXCooper.com
Originally Posted by dandennis123
their isnt any
there is no color on dip stick or oil on the dip stick?
Old Nov 25, 2008 | 08:33 AM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
I'll second that!
Old Nov 25, 2008 | 01:28 PM
robbybee's Avatar
robbybee
their isnt any
Yes!! That could be a serious problem...
IQRaceworks
53
Jun 28, 2024 07:29 AM
Doc Pain
Mar 10, 2021 04:50 AM
Ovrclck
Oct 5, 2015 09:45 AM
eliseo1981
Sep 30, 2015 07:57 PM
pkillur
Sep 26, 2015 01:57 PM
