R50/53 Driving with the air fan (non-A/C) on?
Did a search on this topic, could not really find anything too exact.
I've had a long history of driving my cars with just the air fan on, not with the a/c. I guess its always been something of a comfort level with me, I just seem to think/feel that it keeps the airflow in my cabin fresh and what not. I was just wondering if anyone knows if it has any effect on my vehicles performance at all? I mean I know using a/c will affect mpg's but how bout just running the fan? Does using that little bit of electricity sap engine power? I've been too lazy to run a real-life full tank test so I thought I'd ask around.
P.S. Funny enough, when I get below 10miles on my fuel range meter on my '05 MCS, I have this incessant fear that if I don't turn my fan off I'll run out of gas quicker.
I do this all the time as well, but mostly because my car is livelier without the drag of the A/C compressor, I've noticed virtually no difference in the mileage. You shouldn't run your tank down to the last drop anyway, you never know what you might suck up out of the dregs into your pump or filter.
Another myth is that low fuel may starve the pump of lubrication and cause early bearing failure. This is not the case because the fuel pump sit high in the tank anyway. The fuel passing through the pump is what lubricates and cools the pump, not the fuel that surrounds the pump.
So, do not worry about driving with low fuel, no harm. Just do not ever run out of fuel as you will definately damage the pump in doing so.
I guess I'm old school, when the pickup point was not in the bottom of the tank and fuel pumps were mounted outside the tank - like on my '69 XK-E.....
But your points are valid, the crap would normally be in suspension from sloshing around the tank.........
True--but, Click and Clack, the tapett brothers from Car Talk, said running the radio and other electric items (not the A/C) would only be a minimum drain on the engine and reflect in a very small loss in MPG--sorry, they didn't give a number. But you are right, the result is cummulative and will accummulate.
thanks guys!
Well,
Thanks for the input. I guess I can say that running the fan only has a very slight effect on overall performance. However, the more its combined with other electronic devices(lights, wipers, etc.) the more it effects performance. So while its detriment is barely noticeable I guess there was something to my nagging suspicion.
Yeah thats what I do because I hate the loss of power with the AC running. One thing I did notice which was kind of shocking is if you open your hood, being in a quiet garage, and flick the fan on from completely off and you can hear the engine taking some form of load. I was surprised I didn't think it would be noticeable in any form (tho I highly doubt anything could be felt powerwise)
I was always under the impression that the altenator was a constant loss due to the fact that it's not clutch regulated like the a/c compressor. So wouldn't you be able to run everything and not lose additional power as it's already running ,charging the battery?
It's true that the alternator isn't clutch-controlled, but the greater the current being drawn from the alternator, the harder it is to turn. This increases the load placed on the engine by the alternator.
At the end of the day, power can neither be created or destroyed; the best we can hope to do is convert one form of energy into another (this step is never 100% efficient). The alternator accomplishes this task by converting mechanical energy into electrical energy; the more electrical energy required the more mechanical effort will be required.
[FONT=Calibri][SIZE=3]The alternator is a constant load does not make the engine run any harder as you increase the load. The alternator has two parts the stator (which is fixed) and the rotor which spins free in ball bearing and this is what the engine spins. As one increase the load by adding lights, radio, air condition the initial increase in current demand is draw from the battery. Then the alternator produces enough current to maintain the battery charge as the load increase. [/SIZE][/FONT]
And when the alternator's current output increases to handle the additional electrical load, it becomes harder for the engine to turn it.
Here's a relevant YouTube video. It's pretty cheesy, but starting around the 1:10 mark, the demonstrator shows how it requires more force to turn the generator as more electrical load is placed on it. Granted, it's a generator and not an alternator, but the principle is the same (generating current by moving a rotor inside a fixed stator).
alistaircookie
Oct 8, 2015 10:52 AM
tylewis
Aug 18, 2015 06:53 AM
