R50/53 A/C Blowing upwards?
Old Sep 8, 2008 | 07:09 PM
knipdlo's Avatar
knipdlo
Hey all, I have an 02 JCW, and currently I am trying to figure out the climate control system. When I have the settings on manual, set to panel vents, it blows through the grate right above the speedometer, and barely comes out of the panel vents. When I switch to defrost, it comes out of the defrost vents only, and if set to the floor I only have the floor..
Question is... Can I direct the air/heat/air con through the front panel vents ONLY? or does it have to split between both?
Thanks!
Tim
Old Sep 8, 2008 | 07:29 PM
mauberley's Avatar
mauberley
The grate above the speedo is considered part of the front vents (I think I read speculation/theory that it's for getting air to the rear?) so there's no way to do that. CooperGear offers a cover to place over the upper vent to redirect airflow towards the front, if you want to give that a try.
Old Sep 9, 2008 | 07:31 AM
thecigarman's Avatar
thecigarman
thecigarman's vent mod
I called Coopergear many times and finally made my own. It is still under development but here is the prototype for thecigarman's vent mod:
I took a piece of heavy rubber that would be used as a stairway runner and notched it about 1 inch with notches matching the grate. The resultant tabs were pointed and fit into the top of the grate openings.
You could, of course direct the airflow in either direction.
I had intended to post this later, but if it helps you, that is fine with me.
PsychoRallye
21
Feb 17, 2019 06:08 AM
Chefben63075
Oct 1, 2015 12:04 PM
Brochacho
Sep 29, 2015 10:24 AM
Nicefeet
Sep 27, 2015 11:14 AM
dragonby
Sep 25, 2015 08:10 PM
