R50/53 crankshaft/timing chain/cam gear indexing
Old Aug 29, 2008 | 06:29 AM
rynegold's Avatar
rynegold
error/15690
Old Aug 29, 2008 | 06:44 AM
Deviant's Avatar
Deviant
I don't have my bently manual here so I can't check but is there a tic mark or timing mark on the cam gear?
There usually is and if you turn the engine over so the number 1 cylinder is at TDC then the timing mark on the cam gear would be pointing straight up or at the top of the cam gear.
Didn't see the pictures. It looks like the white dot might be the mark.
Old Aug 29, 2008 | 07:51 AM
rynegold's Avatar
rynegold
error/15690
Old Aug 29, 2008 | 07:54 AM
Dr Obnxs's Avatar
Dr Obnxs
Bentely manual says..
the chain can't hop teeth on the lower gear.
Matt
Old Aug 29, 2008 | 08:13 AM
rynegold's Avatar
rynegold
error/15690
Old Aug 29, 2008 | 03:34 PM
K5Cruiser's Avatar
K5Cruiser
So it ended up being a cracked head. Glad to see you're getting it repaired and hopefully you'll be back on the road soon so you can finally enjoy your MINI.
Fordgt4
Oct 10, 2015 10:42 AM
mk1leg
Classic Mini Talk
Oct 2, 2015 11:35 AM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
