R50/53 Do I need a new clutch? :(
I apologize if this was covered elsewhere, but I could only find info on clutch upgrades.
Here are my symptoms:
Shifting is generaly smooth, except when shifting during higher rev's (seems to be around 4k), 3-4th gear. I get the "grind" or old school throw out bearing noise.
Also, a problem with Reverse. Quite often it won't go into reverse at all until I idle and shift between 3-4th, neutral, then it will release into reverse.
Do I need a new clutch or something else? How much time can I let this continue?
Suggections? I'm at 83k miles.
If it where the actual clutch plates it would probably be slipping and not causing the mishifting you speak of. This sounds like a throwout bearing issue which isnt super uncommon.
Thats my guess at least.
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
