R50/53 Shifting where HP and Torque meet
Old May 17, 2008 | 07:07 PM
  #26
minim8o's Avatar
minim8o
ok, right. I got your meaning now. Correct, that is the point of it all... hold the gear as long as the thrust to the tire's contact patch is more than if you were to upshift... or run to redline.
...much as in the graph you see here for the "DRIVE POWER AND LOSS" graph:
http://www.club202.com/forums/showth...er=6#post72660
I started that thread as 98c43amg and changed my handle to c55m8o after the engine swap... I did this using CarTest2000 w/my C43 AMG after the 5.4L transplant from an E55 using measured torque on the chassis dyno for all the parameter sensitivity analysis.
Old May 17, 2008 | 07:50 PM
  #27
ScottRiqui's Avatar
ScottRiqui
Yep - looking at the thrust-versus-road speed chart for your Mercedes, it looks like you're in the same boat as the MINI:
Since none of the lines ever cross (except that the 4th gear line might *just* be touching the 5th gear line at about 150 MPH), you're better off just holding it in gear until redline, rather than shifting early. And the "thrust" on the vertical axis in the first graph is just wheel torque divided by wheel radius, which is why I like to think in terms of torque rather than horsepower right from the beginning.
Rohdeandschwarz
May 16, 2019 08:59 AM
Grizld700
Dec 30, 2015 10:47 AM
papawhiskey
Sep 14, 2015 05:47 PM
CandorLush
Sep 13, 2015 06:42 PM
SneedSpeed
Sep 2, 2015 05:34 AM
