R50/53 dynoday depression lol
Old May 10, 2008 | 04:39 PM
blkkouki's Avatar
blkkouki
so i had a place that was doing a dyno day 3 pulls for $40 so i decided why not. now this is a floor dyno but i still see some problems
my adds, milltek catback, m7 ddm intake, m7 %16 pulley
now im not much of a dyno sheet reader but this looks not so nice to me
by the way its clickable
thanks
chris
Old May 10, 2008 | 05:06 PM
SPDinNY's Avatar
SPDinNY
wow ya sounds like you need a Jan tune.....what were the others dyno'ing at? Anyone else disappointed in their numbers?
Old May 10, 2008 | 05:12 PM
Motor On's Avatar
Motor On
13% drivetrain loss puts you around 178hp, or 13hp above stock with 3 simple mods, that actually doesn't seem too bad.
Old May 10, 2008 | 05:13 PM
cartar452's Avatar
cartar452
That's pretty bad actually. There could be a boost leak maybe?
Old May 10, 2008 | 05:30 PM
blkkouki's Avatar
blkkouki
after looking with in the last 10 mins i think i had one. the coupler wasnt on all the way on oneside, plus there is aloooot of oil in there , i know the oil is common but i dont think its ever been cleaned before 60k miles
i am also putting on a milltek header in a week or so , then ill go back and hit it again lol
Old May 11, 2008 | 09:26 AM
blkkouki's Avatar
blkkouki
so i cleaned it out and put the the conneciton back right and the but dyno says WOOOOW!
but does anyone know that would a boost leak cause it to dip and dive like that at the top and run out of air?
Old May 12, 2008 | 10:10 AM
mikenaron's Avatar
mikenaron
This is a complete guess, but does it look like the belt is slipping at all from the dyno?
Old May 12, 2008 | 01:48 PM
blkkouki's Avatar
blkkouki
i couldnt tell but they make you stand back when they are running it , i did notice the the one coupler was tilted over on the larger port of the intercooler looked like this \ . so im thinking i had a bad boost leak, cause the car drives different now when shifting
like usually it would kinda jerk between shifts even shifting slowly, and now its more smooth like theres more power when i come off the clutch
Old May 12, 2008 | 01:58 PM
Guest's Avatar
Guest
Doesn't really look like a boost leak. The numbers do look a bit low for a pulley (You're not going to gain any power from the intake really). The peaks and valley's in the pull are just normal dyno variations. If they had set the smoothing higher you would just see a line.
There have been rumors of the 16% M7 Pulley causing some issues with belt grip (Something about the design) but I've never owned one or seen a car on the dyno with one, so I have no idea.
Old May 12, 2008 | 03:16 PM
blkkouki's Avatar
blkkouki
so would i do any better to just get a 17% and call it a day i do have a milltek header on the way
Old May 12, 2008 | 03:21 PM
Guest's Avatar
Guest
I'm not sure. You could spray a bit of spray glue on the belt on the dyno. If you see an improvement in the numbers then you'll know the belt is slipping. If you do use glue, make sure you swap out the belt and clean the pulley afterwards.
What size belt are you using with the 16%?
Old May 12, 2008 | 03:24 PM
Guest's Avatar
Guest
Actually it's either 15 HP or 10 HP. Depending on the year of his car.
The 02-04 Tritec made 163 BHP.
The 05-06 Tritec made 168 BHP.
The bump was from a shift to the JCW Supercharger in 05 which had coated vanes.
The drivetrain loss on the MCS 6-Speed is typically closer to 10-11% though.
Anyway, it's all semantics, the numbers are a bit low, although not overly so.
Old May 12, 2008 | 03:32 PM
blkkouki's Avatar
blkkouki
should i have lost the 25+ hp on my first run in green though? i always wondered why it seemed to pull a little harder when shifting around 6k now i know why , hey the bright side is as long as i shift there i wont have to worry about over reving the supercharger
Old May 12, 2008 | 07:01 PM
jaynicholson's Avatar
jaynicholson
+1 on the need for a tune from Jan. The lines should/could be MUCH smoother. As far as the low #s, some cars are just stronger than others and there are a lot of theories on why. One thing for sure is that some versions of the factory tuning really sucks. Check out this link for the improvement that Jan's tune had on a MCS here in Rochester a few weeks ago.
https://www.northamericanmotoring.co...&postcount=168
Old May 12, 2008 | 07:19 PM
Guest's Avatar
Guest
The jagged lines are just because the dyno graph doesn't have a smoothing factor applied. With smoothing it'd be straight as an arrow.
Old May 12, 2008 | 08:04 PM
blkkouki's Avatar
blkkouki
id love to have jan tune it but the closest he has come to oklahoma since i got the mini was i houston wich is like 6 hour drive for me one way and i dont have any scheduled time off yet. also im debating on trading her up for an 05+ r53 with lsd
but i do understand that it wont be a straight arrow up , its the 25+hp dip i get right after 6k rpm
Old May 12, 2008 | 08:34 PM
Ryephile's Avatar
Ryephile
No baseline [stock] pulls? If not, then you have no idea if it's a good number with those mods on that dyno or not.
Old May 13, 2008 | 06:41 AM
rallymaniac's Avatar
rallymaniac
I for one think that someone did a lousy job at this dyno runs. The last two runs don't start untill like 2800 RPMs and you can see on the fist run (green one) that the torque is already pretty high at almost 2k. As far as the numbers go, they are to the wheels and they will always be lower than the crank HP.
As others mentioned it would help to know what the graph looks like for the stock MCS.
Old May 13, 2008 | 06:43 AM
Revolution Mini Works's Avatar
I have been to Dallas and will be there again at some point as I have property there
Old May 13, 2008 | 06:57 AM
blkkouki's Avatar
blkkouki
well i look forward to your return
RobbyD
Jan 29, 2019 01:22 PM
tEckniks
Sep 29, 2015 11:20 AM
