R50/53 General Care-Taking?
Old Apr 19, 2008 | 04:36 PM
uRabbit's Avatar
uRabbit
So I'm nearing 20k miles on my '03 MCS and I'm freaking out over the fact that I've put 10k miles on it in a year (bought it with 8778 miles - I know, 20k still isn't a lot), and I'm realizing that I need to start doing more upkeep other than oil changes every 8k miles in order to take care of my baby.
So what are some things I could do?
- Clean air filter every month
- Clean fuel injectors? (How?)
- Any additive for my gas tank that'll do anything?
- Anything else!
Thanks a lot, everyone!
Old Apr 19, 2008 | 09:55 PM
Ancient Mariner's Avatar
Ancient Mariner
The easy:
Run some good fuel injection cleaner thru the system (just dump in gas
tank -Lucas, Techron, etc.
Rotate tires front-to-back (opinions may differ).
Drain and flush cooling system (how-to posts on NAM).
Change fuel filter.
Wait for it, wait for it... a number of knowledgeable people will post some very good advice here in the next few days. This site rocks for that kind of thing.
-skip-
Old Apr 19, 2008 | 10:29 PM
Mr. D's Avatar
Mr. D
Keep the engine bay clean, maybe drain and add clean brake, power steering and clutch fluid....
Old Apr 19, 2008 | 10:50 PM
Ancient Mariner
Umm, I'd stay away from the brake fluid flush. Without experience and equipment, that can turn into a nightmare. Clutch shared with brake.
The antifreeze flush can be problem enough: MINI's have a habit of trapping air bubbles in their cooling systems that can be a pain to remove.
It all comes down to mechanical experience. Don't exceed your abilities, you might hurt your best friend (car).
-skip-
Old Apr 19, 2008 | 10:52 PM
Ancient Mariner
If you're really ****, you can change the air in your tires...
-skip-
Old Apr 20, 2008 | 02:36 AM
hoonpv's Avatar
hoonpv
I bought my mini (which had 10K miles on it) about 4 months ago and now i'm at 15K.. And here are things I've done so far and will do at 20K.
done so far: changed oil, oil filter, fuel system cleaner (STP or anything), and new intake filter (K&N)
will do at 20K : Engine oil, oil filter, fuel system cleaner, fuel filter, iridium plugs, clean the intake filter, replace cabin filter, brake pads and rotors (i checked and they are almost out) power steering fluid, and maybe automatic trans fluid.
I'm thinking of smaller pulley, one-ball, and an intake as well at 20K.. i'm not sure though..
Old Apr 20, 2008 | 02:55 AM
cabriopilot's Avatar
cabriopilot
You need brake pads and rotor with only 20,000 miles on the MINI?
What gives? You shouldn't need brake pads and rotors with mileage that low.
Old Apr 20, 2008 | 07:28 AM
doogie1022's Avatar
doogie1022
-skip-
Don't forget to grease those muffler bearings also, good for at least an extra 5hp
Old Apr 20, 2008 | 08:17 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
My stock brakes were completely spent at 18,000 miles.
Here is another suggestion for regular maintenance: The Italian Tune-up. Get the engine warmed up and run to redline in first and second sevral times.
Old Apr 20, 2008 | 09:49 AM
uRabbit's Avatar
uRabbit
Heh. I hardly ever use the brakes, and when I do, it's at under 20mph. Maybe I should be looking at taking care of my clutch assembly.
I get free tire rotations and free flat repairs from the place I purchased my rims and mounted my tires at. So that's done every 4k miles.
Thanks for all the input guys.
Much appreciated.
Old Apr 20, 2008 | 11:44 AM
Ancient Mariner
Dang, doogie! We forgot to mention the blinker fluid! Needs to be flushed and refilled every couple of years.
Old Apr 20, 2008 | 02:07 PM
hoonpv's Avatar
hoonpv
i dunno, but my my brakes are almost out when I checked.
not to mention the brake pedal travels a lot with minimum stopping power.
elverado
Jan 18, 2022 02:51 AM
papawhiskey
Sep 22, 2015 12:24 PM
Lschneider
Sep 22, 2015 07:01 AM
MiteyF
Sep 19, 2015 11:26 AM
Shane Wendel
Sep 18, 2015 06:18 PM
