R50/53 Clutch replacement options?
Old Apr 2, 2008 | 08:37 PM
Squadron's Avatar
Squadron
I'm really glad for this forum, it's been fantastic to hear about all the options out there for the Mini's!
I've got about 54k miles on my 03 MCS, manual, and although I don't feel any problems with the clutch I'm really worried about it. I keep seeing the number 2600 floated around as what it would cost to get it and the flywheel replaced.
So what would my options be? I've heard that in other cars the clutch is something that can be replaced if you have some experience with cars. I don't have a whole lot of experience with manual transmissions, but can generally find my way around the car.
And at this point, performance needs to take a second place to reliability and price at this point. :( So I'm looking for a cheap and dirty replacement.
Old Apr 2, 2008 | 08:47 PM
Guest's Avatar
Guest
If you're just looking for stock replacement, why go aftermarket? Just get a stock clutch. Labor from most reputable shops will cost 900-1200.
If you want something that's pretty nice, the Clutchmasters S3 clutch and flywheel combo are great, and both can be had for under 1k. Check with Jan for more info .
The MINI clutch practically requires the engine to be dropped out of the car to replace it. It's pretty complicated, but can be done if you don't mind getting your hands dirty, and have a good general knowledge of cars.
Old Apr 2, 2008 | 08:51 PM
hemiheaded18's Avatar
hemiheaded18
If you have little or performance mods done, there's no need to spend $400 or more on a clutch. Moss offers a factory OEM replacement for a lot less:
http://www.mossmini.com/Shop/ViewPro...eIndexID=45354
And as far as clutch replacement goes, it gets involved. Quite a bit. If you're one of those "filters, brakes, and fluids" only kind of people, have someone else do it. I'd buy the parts from Moss and take it somewhere to avoid buying parts from them and paying their markup. Labor can run anywhere from $60-110/hour, depending where you go. Bet on the high side for a dealer who's gonna want 7-9 hours labor charge. Not gonna be cheap anyway you look at it.
Old Apr 2, 2008 | 09:37 PM
Some Guy's Avatar
Some Guy
I believe you can do it by dropping the transmission, and that you dont have to remove the motor.
Old Apr 2, 2008 | 09:39 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I just had mine replaced due to this. It was replaced with a factory clutch kit, however, I'm still using the stock flywheel. I've never replaced it. My mechanic says it's it great shape. MINI might recommend changing the flywheel, but it is not necessary.
Old Apr 3, 2008 | 07:39 AM
2Miniacs's Avatar
2Miniacs
It's been my experience that you should have the flywheel turned at least, or replaced, if you're putting in a new clutch.
Old Apr 3, 2008 | 07:46 AM
Guest's Avatar
Guest
You can, but there are a bunch of way's to do it. The dealer does it the hard way .
Old Apr 3, 2008 | 10:45 AM
sequence's Avatar
sequence
MCS dual mass flywheels cannot be turned. They have to be replaced.
Old Apr 3, 2008 | 11:17 AM
roaduscarnivorous's Avatar
roaduscarnivorous
since at least the tranny and/or the motor needs to be *dropped out* for this job, would it be advisable for someone who's interested in a quaife to (might as well) do it while the clutch is being done?
Old Apr 3, 2008 | 12:15 PM
Squadron's Avatar
Squadron
Cool, thanks!
I'm a bit more involved in the maintenance than just the fluids and whatnot, but as of this point I don't have a proper lift (just ramps), so I'm not going to try anything too intense. The clutch still feels good, but it'll probably be one of the things I'm going to need to replace soon. I'll just take it to a good mechanic in the area (not a dealer) and stomach the price, I think, when I need it done.
Old Apr 3, 2008 | 12:28 PM
COR BLMY's Avatar
COR BLMY
1 week before leaving for Vegas CRRIKEY and I both did Clutch / Flywheel / and LSD.
It is a bit involved and the motor does NOT have to come out ..dropped down nut not out. the transmission split and LSD install is easier than you may think (perhaps an extra hour)
One note... & I have never seen any post on this ... Unbolt your exhaust at the cat ...dont JUST flex the flex connector on the header .. the drop needed to be able to line up the trans to enging is right at the point of damaging the flex connector ...it is only 2 more bolts
We did 12.25 flywheels , 4 puck clutch and LSD...
but match your needs to your use
Old Apr 3, 2008 | 03:42 PM
Some Guy's Avatar
Some Guy
Highly recommended you do both at the same time.
eliseo1981
Jan 28, 2021 02:45 PM
Zettinger
Aug 25, 2015 04:04 PM
PrimePower
Aug 16, 2015 06:29 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
