R50/53 Question for ALL Cooper (non-S) owners
This is only for Cooper (non-S) owners:
Please tell me the first problem your car had and the number of miles on it when it happened. Just the problem, not what was done to fix it.
By problem, I mean a warranty fault or defect, not something that you broke.
I'd just like to see what's happened and when.
Later, I will do a post that asks how many Coopers have had no issues and, again, how many miles the car has.
Thanks in advance for your input.
1. Passenger side motor mount was replaced in Nov. 06 (under warranty) bc it was leaking. I think Geoffrey had somewhere between 2000 and 2500 miles at the time.
2. Motor mount bolt (from the motor mount replaced in Nov. 06) fell off and caused a loud thumping sound towards front of car. Bolt found and replaced in Apr 07 at about 8000 miles.
3. Third brake light lens had numerous stress cracks. Replaced under warranty about a month or so ago. Geoffrey had 15k miles then.
1. Third brake light fell off after a car wash, maybe 2 months into ownership (about 1,000 miles). Was not fault of car wash, may be stress cracks as leslie923 mentioned.
2. power steering pump/motor (?) began making noises 1 year and 9 months into ownership (~31,000 miles). turns out pump/motor failed.
Fuel gauge stopped working at 12,000mi. The sensor was defective and replaced twice in 500 mi.
Nothing major on my 06 MC (~17,000mi). The only thing was the air bag sensor under the pass seat failed and was replaced (warrenty). Also the third brake light was loose and replaced. Both right around 14,000miles.
After 2 years and 19000 miles in our 2006 Cooper, we have yet to have a single warranty repair.
But when we took it in for routine scheduled service at 16k, they changed out the cabin air filter because there was a slight funny smell from it sometimes.
My AC compressor wasn't kicking on ('03 Cooper)...it was a loose connector that was easily fixed w/ no reoccurance.
On my '07 Cooper, a rubber seal on one piece of chrome beltline trim was delaminating...they put a new piece on. Also got a CEL and DSC sensor failure...also easily fixed w/o reoccurance.
Just this past summer I had a wheel speed sensor go bad on my 2003 Cooper (took delivery Sept 4. 2003), probably around 26k miles at the time, but like I mentioned on the other thread of yours, it may have been a granule of blacktop got up there. Also, on a VERY hot day this summer I had an issue where my drivers side window would not go down. By the time I got home it was working again and has worked fine ever since. Just thought I'd mention it as you seem to be looking for any and all issues.
Hey Ords...that's how I discovered what turned out to be a leaking thermostat housing. Small puddle (3" dia) under car directly in center (from side-to-side) under the engine. Dealer found the bad housing/o-ring seal and replaced it.
1st year (2002), pulled to left - both front struts replaced. Followed shortly into second year, vibration at 60 mph, both drive shafts replaced. Same year, failure of PS pump. Replaced. 4th year, cooling fan failure, fan and wiring harness replaced. 5th year, 5sp transmission replaced (out of warrenty by a few thousand miles, but I'm a 'plank-owner' at the dearship, and they warrentied it for me. (Helps that I've known the shop forman for years and maintain a very cordial relationship with the service dept.)
While in Warrenty: (Up to 36k)
Seat back on passenger seat got stuck in the down position
Drivers door handle came "unhooked" a few times, I had to roll the window down in the rain to use the outside handle to get out.....
Out of warrenty:
Clutch replaced at 60k
Clutch slave at 81k
Radiator/hose leaking.....I still need to look at that...
I am now comming up on 82,000 on my 03 R50.....
Out of warrenty:
Clutch slave at 81k
