Navigation & Audio XM Radio Antenna Help
Old Apr 27, 2007 | 12:32 PM
StanFrancis's Avatar
StanFrancis
Attempting to hide the Terk XM Micro antenna in the base of a 2006 MCS when I came upon a stumbling block. The 4 screws that hold the base plate on the bottom of the antenna base of the MCS, what size are they (nothing that I have will fit). Also while I am asking what size is the nut that hold the whole antenna unit to roof (I used a pair of duckbill plyers) . Thanks in advance for the help. This is the number 1 source for getting bailed out when you hit that road block or mental block.
Stan
Old Apr 27, 2007 | 01:04 PM
lowb35's Avatar
lowb35
Hey Stan, if it hasn't changed with the later models the nut holding the antenna to the roof is 17mm. Don't know about the other screws since I didn't do anything with those when I did something similar with mine... all I did was loosen the nut on the top of the roof and I was able to route the XM antenna lead through.
Old Apr 27, 2007 | 06:36 PM
StanFrancis
Went to Sears and got a T6 Torx for the base, disassembled a Terk antenna, install the guts of it in the antenna base. I had to drill a hole to feed the wire through the base, would not fit the slot even with the purple plug removed. Everything went smooth, works great even if it was a little nerve racking drilling the antenna base.
Hope your brake job went ok.
Stan
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
