Navigation & Audio aftermarket speakers
Old Apr 10, 2007 | 06:27 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Hey everyone, I am going to be installing JBL three way speakers to replace the factory units. Mine blew The model numbers are; GTO637 and GTO937. The fronts are 6 1/2's and the rear side pannels are 6x9's. I just need to know if my factory unit has enough power to push these speakers?
If not should I replace it with an aftermarket unit(I will stick with Alpine), or can I install an amplifier so that I can retain the factory look and steering controls?
PLEASE HELP
Also, I do not have the H/K.
Also, I want to get the maximum performance out of these speakers.
Thanks to all of you who help with any suggestions.
Old Apr 10, 2007 | 06:41 PM
DjR53's Avatar
DjR53
i would definattely amp em
Old Apr 10, 2007 | 06:52 PM
Alex@Helix's Avatar
Alex@Helix
If you want to amp them but retain the factory head unit you can always go for something like the JL Audio Cleansweep. It allows you to have the benefits of an aftermarket headunit while keeping the stock one in place
Old Apr 10, 2007 | 06:55 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I am also planning on adding a 10" sub this summer. How should I go about adding an amp? Do I add a 5 channel amp so that I can run the four speakers and the sub on one amp? Or do I install an amp (four channel? for the four speakers), and then one for the sub (a mono amp?)?
Please Need More Info!!! AHHH
I am too new to this audio stuff.
Again thanks for the responses.
Also, I do not want to spend all my limbs on these amps.
Old Apr 10, 2007 | 07:02 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
The clean sweep sounds good, but I am not sure if it will do what I need it to. Sounds like it just tunes the stock speakers? Maybe I am not understanding the info correctly.
Thanks though for the suggestion
Much appreciated
Old Apr 10, 2007 | 09:05 PM
DjR53's Avatar
DjR53
that looks like a great audio upgrade for the r56
Old Apr 10, 2007 | 09:26 PM
Alex@Helix's Avatar
Alex@Helix
You could really do it either way. If you want to spend the money, then buy a 4 channel amp for the main speakers, and buy another amp to control the subwoofer.
If you are looking for the more economical route, you can buy a single 4-channel amp, run the two front speakers off of it and use the other two channels to run the subwoofer. Your rear speakers would just be powered by your headunit. I personally did this in my Mazda and was very happy with the results.
As far as the cleansweep, I was under the impression that it can be used for either. I think I remember a magazine article where they used one on an S4 that had a otherwise completely custom stereo. The owner wanted to keep the stock headunit to not draw attention from theives.
Old Apr 10, 2007 | 11:25 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Just do some planning-
You got speakers to power:
Front component speakers
rear speakers
Subwoofer
So that's 4 channels plus the sub
One amp for the sub
plus one four channel amp for the rest
or
One four channel amp to power the fronts and bridge two channels for the sub and drive the rears off the headunit
or
One amp for the sub
One two channel amp for the front component speakers
right now I have
one Boston Amp 275 Watts powering JL steathbox sub
Xtant 4.4i 4 channel amp bridged and powering just the front component MBQuarts (200 Watts per channel)
Nakamichi head unit CD400 powering rear two way 6x9 MBQuarts (50W per channel)
You can add or bridge amps for various combinations of speakers as you upgrade.
Old Apr 11, 2007 | 05:59 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks everyone this is just what I needed to find out.
I will be doing the install in a few weeks, and will try and post pics when I can.
Thanks again
Old Apr 11, 2007 | 01:03 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Hey is it very hard to wire up the new speakers?
If I want to get them installed where should I go.
I am in North West Ohio.
thanks guys.
Old May 13, 2007 | 03:38 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
FINALLY DONE
OK so I finally got my speakers installed. I did 6.5s in the front and 6x9's in the rear. I have the JBL GTO's and they are all three ways! Man I cannot believe the quality of these speakers! I did not buy an amp yet and I really do not think that I need one, the factory head unit powers them plenty. The only thing I have to complain about is now I am itching for a sub...hmm.
Well thank you to all that aided me in this thread.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
Qik420
Oct 1, 2015 12:02 PM
tcjake
Sep 30, 2015 08:14 AM
