Navigation & Audio How much can the alternator handle?
Old Mar 5, 2007 | 08:35 AM
laggy's Avatar
laggy
I would like to run dual Kicker s10L7's witha kenwood x-10d
Kicker --> http://www.millionbuy.com/kik06s10l72.html
Kenwood --> http://www.millionbuy.com/kenkacx10d.html
will i run into any electical problems such as the alternator won't supply the required power or i drain my batter while driving?
and if anyone has a system simlar to what i am creating please enlitghen me as to your installation and any problems you might of run into
Old Mar 6, 2007 | 07:28 AM
Greg S's Avatar
Greg S
Since you will only be running 2-300 watts with those subs according to the Kenwood specs I wouldn't worry about the alternator at all. I doubt you'll pull more than 15-20 amp peak, so most of the time you'll probably be pulling in the 5-10 amp range, which a stock alternator can handle fine.
Old Mar 6, 2007 | 07:55 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The stock alternator can handle that system without any problems. As Greg detailed above, the peak and average current draws are not taxing on the system.
For the '02-'06 cars the MC alternator (Valeo) is rated at 120 amps, the MCS alternator (Denso) is rated 105. The lower rating is due to smaller physical size needed for the MCS alternator to be able to cram it in such a small space.
Old Jul 28, 2009 | 11:14 PM
Cudda_Kine's Avatar
Cudda_Kine
Great lol, i was hoping that i could run two alternators in my MC '05. I have a Clarion DPX11551 running @ 1550watts rms. I was going to buy One more, same amp to run my second sub. How much amps are my subs using if the one i have is 1550watts rms?
Old Jul 29, 2009 | 10:25 AM
Giants9595's Avatar
Giants9595
I have 2200 total watts running in my system but have a cap and I have no problems with anything like lights dimmer whatsoever.
Old Jul 29, 2009 | 01:01 PM
Cudda_Kine's Avatar
Cudda_Kine
Well, if I get the other amp, it will be running at 3100watts rms total. Not sure if that's safe lol.
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
daviday
Sep 25, 2015 01:31 AM
RHcoopers
Sep 20, 2015 10:01 AM
Sc00terbum
Sep 11, 2015 09:07 AM
Sep 10, 2015 11:55 AM
