Strange Aux-In Issue - NO SOUND
Old Aug 10, 2021 | 04:00 AM
InconsistentlyMe's Avatar
InconsistentlyMe
It's odd. The system sees it. I can select it, adjust the volume but, I can't hear it. I GUESS it's a faulty port? I ordered a new one but, here's the thing, I've never used it. Not once. It's pristine. I pulled the part out and checked the pins, also pristine. Cables all are connected and pretty. I don't know what else to do. Is there a second Aux-In somewhere? What do I do?
2013 R59 JCW Roadster
Old Aug 10, 2021 | 08:48 AM
leftfield6's Avatar
leftfield6
Sorry if you already know this, it's very basic. Make sure the volume on your device itself is not set a zero or muted.
Old Aug 10, 2021 | 01:54 PM
InconsistentlyMe
CHECK. Good call. I also should mention that there's no indication of power to that port. You know when you plug in a 3.5mm plug, there's a little static sound that confirms that there's power? Yeah, none of that.
Old Nov 5, 2021 | 01:03 PM
maccoder's Avatar
maccoder
What about the cable you are using to connect device to the AUX port? Can you confirm it's actually working?
TheZlog
R59 :: Roadster Talk (2012+)
May 14, 2013 03:35 PM
Roadster Pilot
Feb 26, 2013 02:52 PM
footballgiant
Jul 8, 2012 02:12 PM
MiNiBeamer
May 2, 2008 09:55 AM
MiniBlue
Mar 14, 2003 10:33 PM
