Navigation & Audio Complete audio install
Old Feb 7, 2020 | 06:18 PM
  #26
varma1986's Avatar
varma1986
I swapped my basic grill (without space for Tweeter) on the rear doors of my F60 with these grills.
The project is complicated & not advisable for the time & labor involved.
Each door is held by 3 screws & once the door panel is open..
Step #1 Break the many plastic welded tabs that connect the grill & the door plastic trim to pop off the old grill.
Step#2 Cut the well market circle in the door plastic trim to accommodate space for the tweeter slot of the new grill.
Step#3 Insert the new grill & align all the tabs into the previously broken tab slots of the old grill.
Step#4 Choose to plastic weld or superglue the tabs into the plastic such that the new grill is locked in its place.
Step#5 Pop in the new tweeter into the grill & connect & test.
Step#6 Put back all the trim & screws back as original.
The project is possible but tedious & laborious.
Old Feb 7, 2020 | 06:24 PM
  #27
varma1986's Avatar
varma1986
Old Feb 7, 2020 | 08:00 PM
  #28
Katgirl's Avatar
Katgirl
Originally Posted by varma1986
That is why I am paying a pro to do my stereo upgrade. I will report back Tuesday on how it sounds.
Kat
Old Feb 8, 2020 | 03:39 AM
  #29
varma1986's Avatar
varma1986
There is no option here for this upgrade becoz BMW has "Machine welded the plastic of the old grill to the plastic of the car door inner trim".It needs to be cut out and the same holes are to be used to push the new grill into.
Old Feb 8, 2020 | 03:43 AM
  #30
varma1986's Avatar
varma1986
The BimmerTech Amp is from German maker "MATCH-Helix" and model PP86DSP 8 channel Audio & more powerful & more ways to custom.It is many times superior to the HK stock amplifier by BMW/MINI.
https://www.audiotec-fischer.de/en/m...fiers/pp-86dsp
Old Feb 8, 2020 | 10:45 AM
  #31
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Two dixie cups and string are better than HK amp.
Seriously tell us about all those funky upgrade trim pieces in your car, they are wild! I feel like I'm on an LSD trip looking at those.
Old Feb 8, 2020 | 11:17 AM
  #32
Katgirl's Avatar
Katgirl
How about 2 soup cans and a string? 😂
Old Feb 8, 2020 | 12:53 PM
  #33
6FT6's Avatar
6FT6
I’ll be getting that amp first then.
Wild is an understatement!
Old Feb 12, 2020 | 02:55 PM
  #34
varma1986's Avatar
varma1986
https://www.ebay.com/itm/124081675225
Please check out my listing if you are interested.Thanks.
Old Jun 21, 2021 | 10:23 AM
  #35
MasAyinde's Avatar
MasAyinde
This thread is fascinating because it looks like the JCW I will be ordering will not come with HK. I was hoping to upgrade to Alpha One and order their HK replacement kit, but I wanted to make sure that all of the wiring was there to accept the kit. It looks and sounds like this is the case, right?
Old Aug 21, 2023 | 07:22 AM
  #36
omuroff's Avatar
omuroff
Hello all, a massive bump after years,
We have a F54 with Base Audio. It sounds like just upgrading the speakers is not cutting it. I am thinking about changing to aftermarket amplifier prior to everything. Because the signal being sent to the rear speakers is just prefiltered and really weak.
How logical is this? I am planning to continue with the speakers from there,
Thanks,
Ömur
frankthetank77
20
Jan 12, 2024 11:12 AM
mountainhorse
Mar 24, 2019 02:42 PM
Norcal_Cyclist
Nov 28, 2010 03:12 PM
wetceal
32
Aug 30, 2008 10:00 PM
