Navigation & Audio antenna amplifier (not diversity module)
Old May 19, 2015 | 05:11 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
anyone know how to get to the antenna amplifier located behind the left rear trim panel? on a 2009 R56 base radio? I'm not exactly sure where it's located but it's on the wiring diagram as a separate module
I already replaced my diversity module so the antenna amp is next on the list
Old May 21, 2015 | 02:23 PM
MrBlah's Avatar
MrBlah
Still working on the car, I'm getting 11.87 volts at the diversity module power wire, that enough to operate it properly? The reception does die when I unplug the power wire
the battery tested at 12.5 to 12.3 and my solar cont tester says it's still good
I should also note, my 2nd key is brand new and it has the same range issues
Old Jun 3, 2015 | 04:58 PM
MrBlah's Avatar
MrBlah
Still no luck, anyone know where the radio module is located? on bmw's they put it back in the trunk
Old Jun 7, 2015 | 07:22 AM
MrBlah's Avatar
MrBlah
still working on it, does anyone have a diagram for the right and left side filter/traps and what those antenna wires are going to?
I'm bypassing all of the crap now and have a stick on antenna feeding the radio directly, until I can figure out what is causing the problem.
gar56
Nov 15, 2016 06:41 AM
GAT
Oct 4, 2015 07:27 PM
simo711
Oct 1, 2015 05:36 AM
Emnotek
Sep 29, 2015 07:37 AM
Sep 25, 2015 12:32 PM
