Navigation & Audio Blown HiFi speaker replacement?
Old Apr 2, 2015 | 07:29 AM
Tu13es's Avatar
Tu13es
One (or more) of my Hifi speakers in my 09 JCW has blown, I think - I get lots of crackling in bassy songs. Is there an aftermarket speaker I should consider using as a replacement? Or should I stick with OEM speakers?
I don't plan to change the amp or add a subwoofer or anything.
Also, is there a good source for these speakers? According to this page, I'll need part numbers 65133422637 and 65139143153, which don't have many web hits (though there are a few, just none of my usual MINI sources).
Thanks!
Old Apr 8, 2015 | 10:58 AM
Hello,
In 9/2009 MINI went from HiFi ( -9/2009) to Harman Kardon HiFi (9/2009+) .
If the speaker pop and crack individually its the speaker, if its all of them , it may be the amp. To know if you have the HK ( harman kardon ) look for the a pilliar speaker on the dash that states Harman Kardon on 9/2009+ . Pre 9/2009 with Hifi have a tweeter speaker on the dash a pillair but it black and does not say anything on the grille.
www.ecstuning.com
Old Apr 8, 2015 | 11:56 AM
Tu13es's Avatar
Tu13es
Hello,
www.ecstuning.com
It's definitely just individual speaker(s). I've got the HiFi system (my car was built in mid 08, and is an 09MY).
Old Apr 8, 2015 | 12:05 PM
Ok, thats good, just wanted you to know.
I isolte each speaker and change the volume to determine which one is blown. Its easy to replace them , some guys change them out to the HK ones.
https://www.northamericanmotoring.co...h-k-sound.html
Since they are same size. And keep the HiFi amp.
http://www.ecstuning.com/Search/SiteSearch/65133422637/
HiFi Midrange Speaker - Priced Each 65139143153
http://www.ecstuning.com/Search/SiteSearch/65139143153/
Some people do the front / rear channel swap on the Hifi system.
https://www.northamericanmotoring.co...nnel-swap.html
Old Apr 9, 2015 | 05:55 AM
trinigladiator's Avatar
trinigladiator
I swapped out my HiFis for the HKs for better sound quality. I can check if I still have them if you're interested.
Old Apr 9, 2015 | 06:07 AM
Tu13es's Avatar
Tu13es
Quite possibly. How did you find the upgrade in terms of SQ, and how much did it run you?
Old Apr 9, 2015 | 08:50 AM
trinigladiator
It was in the 300-400 range I believe. I swapped out all speakers except for the A-pillar tweeters. However, the larger speakers in door panel were the best bang for the buck.
woodstudio
Mar 15, 2020 08:28 AM
triple5soul
21
Jul 29, 2016 04:27 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
bugeye1031
Aug 15, 2015 08:14 AM
