Navigation & Audio Android Tablet
Old May 11, 2014 | 04:33 PM
LawlessCrayon's Avatar
LawlessCrayon
Android Tablet
Hi All,
I am thinking of mounting an old(ish) android tablet in my Mini Cooper S Hardtop. I have been looking into this a bit but have a few questions:
1. Does anyone have experience with the Proclip mount, link, good or bad?
2. Does anyone know of an OBD to USB(microUSB) cable that will work with an android app? I believe my device to have a USB host controller.
3. Is there a preferred android app for OBD real time gauges and whatnot?
4. How do I get 12v 1.5a to my device without using the cig lighter adapter?
5. I believe my device to have an independent GPS antenna and I will have a hotspot capable smartphone with me at all times to download map and traffic data...any pitfalls here to be aware of?
6. Are there any mods to android or other apps that I should be aware of? I am not afraid to root the phone, as I will have to do that to upgrade the OS anyway.
Thanks to all.
Old May 11, 2014 | 06:19 PM
AZdsrt's Avatar
AZdsrt
Just use Blue Tooth, lots of OBD scanners out there use it. I paid $20 for mine off Amazon and you don't need to mess with cables.
I use Torque. There is a free version, it was good enough that I bought the paid version (am thinking it was $5). Way more gauges than I'll ever use.
Don't have any answers to your other questions..
Old May 12, 2014 | 02:00 AM
rkw's Avatar
rkw
That would be USB On-The-Go (OTG) capability (see the note about cables). The problem is that the app you are interested in would have to support this mode of operation, and it probably doesn't. Check the specs of the mobile app to be sure. Bluetooth is the standard way to connect.
You can get a tap from the fuse box by using an
Add A Circuit Add A Circuit
. Choose one of the switched or always on fuses according to your need.
That should be no problem at all. If a location-based app can get location (through the device's GPS) and has an internet connection (wi-fi tethered to your phone), it will run normally.
Old May 12, 2014 | 03:36 AM
Striped Toad's Avatar
Striped Toad
I know this is 2nd gen, but, here's a tablet install...
Old May 12, 2014 | 04:30 AM
Smoothmove's Avatar
Smoothmove
I am an IPad person, but there is an app called Drive Assist which has a GPS and several dashboard goodies in it that I use in my dash mounted ipad Mini. They may make and Android Version
I did a simple Velcro mount which holds well and is easily removable if needed. https://itunes.apple.com/us/app/driv...660222655?mt=8
https://www.facebook.com/driveassistapp
miniuy
Oct 7, 2016 12:09 PM
bcman
Aug 28, 2015 04:47 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
schatzy62
Oct 24, 2011 11:05 AM
androidphil
Mar 12, 2011 03:52 AM
