Navigation & Audio new mini connect update released - UPD01005
Old Jan 9, 2013 | 08:25 PM
worrynot's Avatar
worrynot
http://www.mini.com/connectivity/
Software update
Content
• Office: Improved support for email messages.
• Telephone: Improved connection setup with
certain devices. For certain devices, better display
and stability during calls. Improved Bluetooth
connection with HTC devices.
Support devices
The software update improves the compatibility of
the following devices:
Phone
• Apple: iPhone (iOS 5)
• Au: IS03
• Blackberry (OS 6.x), Pearl, 9800, 9900
• DoCoMo: Galaxy S SC-02B, NEC MEDIAS N-04C,
Samsung Galaxy S II SC-02C, Sharp Aquos phone
SH-12C, Xperia Acro SO-02C, Xperia Arc SO-01C
• HTC: Sensation, Trinity
• Nokia: C7, N8, X7
• Samsung: Galaxy S II (Android 2.3.3), Nexus S
• Sharp: au IS03
• Sony Ericsson: W205
• Verizon Wireless: Casio C781, ZTE F450,
Pantech 8992
Old Jan 9, 2013 | 10:18 PM
biggripper's Avatar
biggripper
Has anyone done the update yet. I've never done an update before. All you need is a thumb drive right?
Old Jan 9, 2013 | 10:46 PM
worrynot's Avatar
worrynot
Correct.
1. Format the drive as FAT
2. Copy the BIN file to the root.
3. Plug the thumb drive into the port below the hand brake (not power usb in the glove box).
4. start the ignition (won't update unless the engine is running)
5. MINI Connected settings - Software update
6. Update. takes about 4 minutes.
7. Changes won't take effect until bluetooth is recycle/car restarted.
Pretty straight forward, you can also roll back the firmware revision, it's listed in the settings menu.
Old Jan 9, 2013 | 10:49 PM
MiniDan's Avatar
MiniDan
I just did the update using a 16GB thumb drive. Previously I have only been able to get my iPhone 5 to sporadically connect with MINI Connected. It connected fine after the update, but I'll have to wait and see how much it has improved.
Old Jan 12, 2013 | 11:35 PM
MiniDan's Avatar
MiniDan
I don't know what this update really does, but it didn't help my iPhone 5 connectivity. It connected on the first try, but after a few minutes it disconnected. By disconnected I mean MINI Connected did not see the phone, and although it was shown as an external device it wouldn't play music. This is the same sort of behavior I saw before the update.
The update information references "improved compatibility" with iPhone (IOS 5). Of course iPhone has been up to IOS 6 for months. Maybe there will be improved compatibility for that in another year or so.
Old Jan 13, 2013 | 12:42 PM
FIRESTARTER's Avatar
FIRESTARTER
I am trying to update my 2013 JCW Hardtop and for same reason my car wont detect my USB drive?
Old Jan 14, 2013 | 02:28 PM
kidziti's Avatar
kidziti
Successfully updated. Was going to do it in the garage last night but the engine needed to be on, so I waited until it was back outside today. Took a total of 5 minutes. Remember to use the USB port that the iPhone/iPod connects to in the center console.
Also it might be a good idea to take note of the software version right before updating, and recheck the version after updating to ensure the update actually occurred.
Old Feb 4, 2013 | 07:19 PM
kconner5's Avatar
kconner5
Just about to go do the update right now :-)
Kyle
Old Feb 9, 2013 | 08:42 AM
mikeruoc's Avatar
mikeruoc
What port do we use in a 2013 Hardtop? There is the USB port in the center console in front of the cup holders but that is all I see? Is there another one hidden?
Old Feb 9, 2013 | 02:46 PM
fchris's Avatar
fchris
Is anyone else using mac to download update. When I download file it is a zip file. When I open zip file it reveals a Folder: UPD01005. When I open folder it has 5 items in it. One file is a .xml and other 4 are .bin files. Which one/all should I transfer to the thumb drive root? I have tried various file combos and the zip drive is not recognized my the mini connect software update. Either my thumbdrive (which is formated in FAT) is bad or the mac operating OS is the problem. Anyone out there used a mac successfully.
Old Feb 11, 2013 | 10:13 PM
esbeale's Avatar
esbeale
I downloaded to a Mac. Once you unzip the zip file, you will have a .bin file. That is what gets copied to the flash drive for installation.
Old Feb 11, 2013 | 10:28 PM
esbeale's Avatar
esbeale
A bit more. I believe that a .bin file can be further unpacked, but you don't want to do it. Once the file was downloaded, rather than unzip using the finder (which unpacks to far), open a terminal window, cd to where the .zip file is, and then type the command
unzip {file name}
where {file name} is the .zip file. You should then have a single .bin file.
Old Feb 12, 2013 | 11:53 AM
fchris's Avatar
fchris
esbeale, Thanks for the reply. Your info worked perfectly. I have been hacking Panny gh1 & gh2's for several years and the methodology is similar except I used Sandisk memory cards instead of thumb drives. Opening in terminal was the answer. Interestingly when unzipping from the finder a single .bin file flashes very briefly disappears and you end up with the wrong files. I talked to two different dealerships and neither one were any help. I'm not sure they were even aware of any updates for MINI Connectivity. Only mac people will have issues. Thanks again for your help. Greatly appreciated.
Old Feb 12, 2013 | 08:22 PM
nfo's Avatar
nfo
The free StuffIt expander will expand the zip without decompressing the bin file as well on the mac.
Old Feb 13, 2013 | 03:49 AM
cactusbob's Avatar
cactusbob
There is actually a UPD01006 available if you go to www.bmw.com/update and enter the last 7 characters of your VIN.
Full details here
Old Feb 14, 2013 | 06:50 PM
mikeruoc's Avatar
mikeruoc
Has anyone flashed this yet?
Old Feb 14, 2013 | 06:57 PM
fchris's Avatar
fchris
Yes, updated to UP01006 this morning. No problems.
Old Feb 14, 2013 | 06:59 PM
fchris's Avatar
fchris
From what I have read the Connectivity Hardware/Software for both the MINI & BMW seems to be the same.
Old Feb 15, 2013 | 12:54 AM
cactusbob's Avatar
cactusbob
Worked fine for me
Old Feb 15, 2013 | 02:10 PM
nfo's Avatar
nfo
updated today with no issue as well.
Old Feb 15, 2013 | 03:08 PM
esbeale's Avatar
esbeale
Same here. No problems.
Old Feb 16, 2013 | 08:01 AM
mikeruoc's Avatar
mikeruoc
Just updated mine also. All good.
Old Feb 17, 2013 | 12:04 PM
iconfessimageek's Avatar
iconfessimageek
Updated mine with e BMW update too (UPD01006)...but what does it give us extra?
Old Feb 18, 2013 | 06:01 PM
the barking dog's Avatar
the barking dog
Release notes said something about better support for iPhone 5 and IOS 6. Only thing I've actually noticed is a progress bar when playing audio from Bluetooth.
EDIT: Aw, heck, here's the full release notes:
Software update information
File name: UPD01006.bin Content
status is shown in the vehicle under "Show cur- rent version".
Notes
Once the software has been updated, the soft- ware in the vehicle is restarted and data trans- ferred from the USB device resynchronised where necessary. Wait a few minutes until the USB device is operational again.
Tracks or playlists played before the software update must be selected again. This is also necessary is the previous version of the soft- ware is restored using "Restore previous ver- sion".
Before you start a Teleservice update, make sure that mobile wireless reception quality is good by checking the status indicator on the control display.
Software update (MX-3.5.4, TX-3.5.6)
Content
> Office: Improved support for email mes- sages. Improved display of text-message sender on iPhone devices with iOS6.
> Telephone: Improved USB connection for iPhone devices with iOS 5. Improved con- nectivity of certain devices. For certain devices, better display and stability during calls. Improved Bluetooth connection with HTC devices. Improved sorting of the phone book in Android devices in Japan.
> Multimedia: Improved display of additional album and track information. Improved con-
The content of the software update depends on the status of the software installed in your vehi- cle. See the description below for details of the content of the update and the devices sup- ported.
From those listed below, the version that is appropriate for your vehicle is installed:
> MX-3.5.4, TX-3.5.6 > TX-2.6.6
> MX-1.12.0
Conditions
The software update is available only for certain vehicles equipped with a USB audio interface. In these vehicles, the main menu "Settings" includes the menu item "Software update". Further information is provided in the Owner's Handbook for Vehicle under Software Update.
Go to www.bmw.com/update or the compatibil- ity matrix at www.bmw.com/bluetooth to find out whether your vehicle is supported.
Installation
Installation of the software update requires agreement with the terms and conditions of use. For further information, see www.bmw.com/update. For the purposes of installation, save the software update file in the main directory of a USB device. Observe the additional instructions in the Owner's Hand- book under Software Update. Following instal- lation of the software update, the new software
© 2012 Bayerische Motoren Werke Aktiengesellschaft
Munich, Germany
English XII/12 Readme_UPD01006_ENG.pdf
nection and control in Bluetooth audio devices.
> Improved functionality of TeleService, BMW Online and Internet for iPhone devices with iOS 5.
Supported devices
The software update improves the compatibil- ity of the following devices:
Notes
Following installation of the software update, the following software status is shown in the vehicle under "Show current version":
> MX-3.5.4 > TX-3.5.6
Software update (TX-2.6.6) Content
> Office: Improved support for email mes- sages. Improved display of text-message sender on iPhone devices with iOS 6.
Supported devices
Phone
> Apple: iPhone 3GS, 4, 4S, 5 (iOS 5, iOS 6)
NEC MEDIAS N-04C,
Sharp Aquos phone SH-12C,
> LG: Enlighten VS700
> Motorola: DROID RAZR 4G
> Nokia: C7, N8, X7
> Sharp: au IS03
Multimedia
> All USB devices
> Apple: iPod touch, iPhone
> Archos: 3 Vision
> Creative: MuVo V100
> Iriver: E100
> Palm: Pre
> Sony Ericsson: C905
> Symbian Foundation: S60
> Yari: U200
Phone
NEC MEDIAS N-04C,
> LG: Enlighten VS700
> Nokia: C7, N8, X7
> Sharp: au IS03
> Sony Ericsson: W205
> Verizon Wireless: Casio C781, ZTE F450, Pantech 8992
> Sony Ericsson: W205
Pantech 8992
Notes
> TX-2.6.6
Software update (MX-1.12.0)
Content
> Improves the speed and stability of music playback from a USB device that is con- nected to the USB audio interface in the centre armrest and contains multiple play- lists.
Supported devices
Multimedia
> All USB devices Notes
> MX-1.12.0
Last edited by the barking dog; Feb 18, 2013 at 06:05 PM. Reason: added release notes
Old Mar 7, 2013 | 07:11 AM
daveag98's Avatar
daveag98
Question on updating: I have tried twice following the instructions from the first page to update my software and get File Invaild.
What am i doing wrong?
I got the file direct from MINI's page and formated FAT and extracted the zip to the root of the flash drive.
Any help will be most welcome.
