Navigation & Audio Bass600 blowing cig adapter fuse
Old Sep 19, 2012 | 07:38 PM
isthar's Avatar
isthar
Hello...
I've been using a Boss Bass600 since 2009 at the back of my Clubbie... And then the other day I noticed it wasn't working. I'm using a RadioShack 12v adapter to plug at rear cig socket - the adapter has a 10A fuse in it. It was blown. Bought new ones and now I realize every time I plug it back in w subwoofer word up, fuse blows. How can I diagnose?
Thanks, Eddie
I
Old Sep 20, 2012 | 10:20 AM
mjg's Avatar
mjg
Thats not enough juice coming thru that to effectively power the sub. Fuses blow because too much current goes thru for a sustained time frame. The amp is drawing too much power. Run a direct power line from the battery with a bigger fuse and you should be back in business and sound better.
Old Sep 20, 2012 | 10:32 AM
isthar's Avatar
isthar
But it's been working for about two years...
Old Sep 20, 2012 | 11:58 AM
rkw's Avatar
rkw
Does the fuse blow right away? If it does, there's a short somewhere. The unit might have gone bad, or connection along the power path. It could even be the cigarette plug or socket. See if it does the same if you plug it into the front cigarette socket.
Old Sep 25, 2012 | 03:52 PM
isthar's Avatar
isthar
Fuse blows right away yeah. What's the best way to tell if the sub itself is done for/causes a short? Before I go off and buy a new one...
Old Sep 25, 2012 | 04:27 PM
rkw's Avatar
rkw
First thing to try is plug it into the front cigarette lighter. If the fuse still blows, then you've verified that the problem is in either the Radio Shack adapter or the sub. If you have an electrical meter or tester, test for a open circuit between the + and - power terminals of the sub, and check for a short in the adapter.
Old Sep 25, 2012 | 05:04 PM
isthar's Avatar
isthar
Well that's the thing - if I touch the + and ground/- on the sub my multimeter shows some life... Pretty much same resistance as if I just touch the multimeter ends... But isnt that Normal? (That there is a circuit there if a battery was present right?)
Kinda forgot my electric basics...
Old Sep 25, 2012 | 06:48 PM
rkw's Avatar
rkw
Did you mean touch the multimeter ends together? The reading for touching the multimeter ends together is for a short circuit. If you see that when touching the power terminals on the sub, then the sub has a short circuit. Try it also with the Radio Shack power adapter (disconnected from everything else).
Old Sep 26, 2012 | 05:11 PM
isthar's Avatar
isthar
Correcting a bit what I wrote above.
Multimeter calibrated so touching ends together reads no resistance -- 0k ohms.
The sub has a 15A fuse that if I pull out and connect the multimeter to sub ground and +12v it reads like 20-50k ohms.
When I put the fuse in the sub and try again I read 0k ohms.
Bad sub?
Edit: this is an amplified sub...
Old Sep 26, 2012 | 06:58 PM
rkw's Avatar
rkw
It shouldn't read 0 ohms, and I would say that the sub is has gone bad. If you can open it up, see if anything inside has burn marks.
Old Sep 27, 2012 | 08:32 AM
isthar's Avatar
isthar
For now I just ordered a new one... Will see how a new one compares from a multimeter POV and hope it all just works!
Old Sep 28, 2012 | 05:15 AM
isthar's Avatar
isthar
And sure enough everything works again. Resistance on a working sub reads a non zero reading that slowly increases...
Filmy
15
Jun 6, 2023 06:27 AM
Sep 24, 2015 02:30 PM
Sep 24, 2015 02:27 PM
Sep 22, 2015 02:05 PM
Sep 14, 2015 12:48 PM
