Navigation & Audio Alpine KTP-445U amp install
Old Jan 27, 2016 | 04:23 PM
  #51
KindaCoolDad's Avatar
KindaCoolDad
I'm getting a 3-4 second delay before my speakers come on when I turn on the car. Anyone else get this, or did I feed the power wire into the wrong fuse?
Old Jan 27, 2016 | 06:02 PM
  #52
digitalsabre's Avatar
digitalsabre
This is normal for that amp to power up. I've noticed it's slightly longer when it's cold outside.
Old Jun 23, 2016 | 03:55 AM
  #53
perryinva's Avatar
perryinva
Since I have the HIFI version in my 3/08 build MCCS, which has totally different rear speaker layouts, would it makeany sense to put in 2 of these style amps, and just use them as power boosters from the anemic OEM amp? Then I could upgrade speakers at my leisure.
Old Aug 11, 2019 | 11:00 PM
  #54
giorgos's Avatar
giorgos
Originally Posted by digitalsabre
After tapping into all of the speaker inputs and outputs, I ran a ground to a nut just below the bonnet release latch. Any good bare metal spot will suffice for ground. Next, the power wire was run along the firewall through the back of the center console, and behind the top of the carpet over to the fuse panel on the passenger side. I purchased a "add-a-circuit- fuse holder form the parts store (Autozone, etc) for about $7. You will also need about 4 feet of wire ( I think it is 12 guage) to extend the amp's power lead. I crimped the extended power lead onto the "add-a-circuit" power lead. I then pulled the Radio Fuse, put the "add-a-circuit" in the radio spot and put the fuse into the "add-a-circuit". The amp is just secured up under the dash with zip ties. BE SURE NOT TO OBTRUCT THE BRAKE PEDAL, OR ANYTHING ELSE THAT WOULD AFFECT CONTROL OF THE CAR! Also, no need to worry about the amp heating up, class D circuitry runs very cool, and will not be a problem with ventilation.
First of all, many thanks for your write up! I had abolished the idea of installing an amp in the front (in order to avoid running several wires front-to-back and back-to-front) but seeing your post made me re-consider.
Could you please elaborate on where exactly behind the dash you placed the amp? What did you fasten it with zip ties to? Is the space there sufficient to use a different sized amp with dimensions: 50 x 145 x 193.6 mm (if I am not mistaken 2" x 5,7" x 7,7")?
There is plenty of space behind the lower panel underneath the steering wheel, but I fear accessing it (i.e. getting hands in there) will be difficult. Also, I didn't see anything there (or elsewhere at the driver's footweel, in fact) to fasten the amp to. I only used my phone to take a video of the area behind the lower panel and the area around and above the pedals so I very well may have missed a good spot.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
