Navigation & Audio Trunk 12V socket and subwoofer
Old Sep 21, 2011 | 05:14 AM
synzeus's Avatar
synzeus
So, i 've got an amplified subwoofer and the kickwell connection speaker splice loom from Mike. Can i connect the sub to the 12v socket in the trunk or i 'll have any problems?
Old Oct 21, 2011 | 11:51 AM
synzeus's Avatar
synzeus
http://www.youtube.com/watch?v=yuIPDXnMCeY
did it..
Old Oct 21, 2011 | 11:55 AM
strobeyprobey's Avatar
strobeyprobey
WOW! that's a tight fit
Old Oct 21, 2011 | 12:01 PM
AXO's Avatar
AXO
YouTube link not working. Looks awesome.
Old Oct 21, 2011 | 12:23 PM
automan21's Avatar
automan21
Nice, is that just a powered subwoofer? Im looking for more bass out of my stock system. It looks like this is the way to go.
Old Oct 21, 2011 | 12:48 PM
synzeus's Avatar
synzeus
youtube link fixed.
Yeah, its amplified.
Old Oct 21, 2011 | 12:53 PM
Mini2na's Avatar
Mini2na
Nice looking installation. Tell us more about it. Did it just slip in after purchase and hookup? Speaker level inputs and 12V from the accessory port?
Old Oct 21, 2011 | 12:59 PM
synzeus's Avatar
synzeus
Well i purchased the 2nd gen kickwell connection speaker splice from newministuff.com.
Its plug n play to the X9931 connector and has right and left channels (cable).
A line towards the battery, remote amp turn on at the boot's cig lighter and ground anywhere at the car... Easy fit.
Old Oct 22, 2011 | 05:15 AM
richardsperry's Avatar
richardsperry
Well it depends on what that ligher/socket is rated for. At max power (200W) it could be pulling 14.2A (P=I*E, 200=I*14V, I=14.2A) or there abouts...
Not sure I'd do it...
Old Oct 22, 2011 | 06:58 AM
ScottRiqui's Avatar
ScottRiqui
That's a good point - I looked at the small-gauge wiring going to the socket and decided I wouldn't ever use it to supply any high-drain electronics, especially since the battery is in the trunk anyway. If the options were either using the socket or running a long wire from the trunk to under the hood, then I might be tempted to give the socket a try. At worst, you'll blow the socket fuse and then you'll know you have to try something else.
Old Oct 22, 2011 | 09:34 AM
rkw's Avatar
rkw
It's an R56 (battery in front), but I agree that it would be better to run a separate power line.
Old Oct 22, 2011 | 09:39 AM
ScottRiqui's Avatar
ScottRiqui
Thanks for clarifying that point - I didn't know whether all of the R56 cars had the battery in the front, or if it depended on model, like the first-gen cars.
Old Oct 22, 2011 | 11:13 AM
synzeus's Avatar
synzeus
I have a separate line from the battery. I used the boots cig lighter for the amp turn on..
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
FatherG
Sep 29, 2015 02:47 PM
EVMini
Sep 28, 2015 10:20 AM
rt808
Sep 25, 2015 01:59 PM
