Navigation & Audio Couple of Nav Questions
Old Aug 26, 2011 | 11:43 AM
blacter's Avatar
blacter
I have nav on my 2011 Cooper. Not the greatest system in the world, but it does the job and I've got most of it figured out. Here are my questions, though:
First, is there a detailed instruction manual somewhere. The nav section in the MINI owner's manual is fine for an overview, but seems short on details.
Second, can one of you explain the A to Z search on the "Point's of Interest" screen. I'm not getting it.
Third, on a recent trip I saw a small black triangle to the left of the bars that show the phone signal. I think it's connected to the fact that I was out in the boonies. (The triangle doesn't show up when I'm in town). Any of you know what that triangle is telling me?
Old Aug 26, 2011 | 08:16 PM
rkw's Avatar
rkw
Wow, sounds like they might have finally fixed this in the Nav system. In all previous versions of Nav on the MINI (for the past 10 years), you couldn't search for a place name or business directly. You had to hunt through different categories looking for which one it might be cataloged under (often it would be in a category you might not expect). There have been complaints for years and requests for the ability to search directly. So can you now enter directly, say, "Safeway" ? Previously you had to drill down through the categories.
A triangle is commonly used on cellphones to indicate roaming mode. That means you are outside the coverage of your own cellular carrier, and if you make a phone call it will be handled by an affiliate carrier in that area. Depending on your cellphone plan, a roaming call might be billed at a higher rate then a regular call.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
OYWHATNEXT
Navigation and Audio
12
Jun 14, 2016 09:36 AM
kevinminict
Jun 3, 2016 01:31 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
Bennyboy
Aug 18, 2015 07:28 AM
