Navigation & Audio Integral Audio Soundstage upgrade
Old May 15, 2011 | 01:28 PM
  #26
Kevin@Integral Audio's Avatar
Originally Posted by biggripper
How will your new soundstage upgrade address the H/K system's utter lack of customization when it comes to system EQ? Will there be the ability to dial in via the amp? If so, will the be in an easy to access location?
It will address it by eliminating the need for it. EQ is there to fix problems - problems caused by deficiencies in the speakers, and problems caused by the environmental acoustics. With careful vehicle-specific design, we can achieve accurate response without the need for additional manipulation. You won't have any additional controls with our system, but you won't care because you won't need them.
For anyone who likes to use EQ to color the sound to something other than what would be heard at the original performance....well, we won't be able to help there. You'll still have the Bass & Treble shelving filters in the HU, but that's it.
Old May 15, 2011 | 02:06 PM
  #27
OSPalmer's Avatar
OSPalmer
Kevin,
What do you think we are looking at in terms of cost for the total upgrade on the base R56 sound system? Assuming this includes speakers, amps and sub how hard will the install be and when do you anticipate it's availability?
Best,
Oliver
Old May 15, 2011 | 02:27 PM
  #28
The subwoofer system is already available - http://www.integralaudio.com/index.p...er-system.html. It is $949 (the $899 intro price listed expires tonight), plus expect about $275-300 to have a professional install it. The Soundstage upgrade will be in that ballpark as well.
The combined Soundstage + Subwoofer upgrade will be on the order of $200-300 less than the combined price, and installation of the combined upgrade should be about $350. Basically this is priced at or a little below the old MINI DPSM upgrade, but with drastically better performance (and, of course, an entire proper subwoofer system).
Old May 16, 2011 | 07:15 AM
  #29
white3's Avatar
white3
Kevin,
For those of us that have already installed your subwoofer system-
a) Will there be some sort of price break if we get the soundstage upgrade.
b) Will it be a problem that the connections for the "older" subwoofer are different than your new model.
c) What happens to the HK amp that we have in the boot on the HK systems?
Thanks!
Old May 16, 2011 | 10:26 AM
  #30
Originally Posted by white3
Kevin,
Yes. The price to add the Soundstage to an existing Integral Audio subwoofer system will be in line with or below the discounted package price. I aim to reward anyone who has already purchased and installed the subwoofer system!
No. I will be putting together a kit that will include anything you'd need to address any connection issues.
It will remain, and will continue to drive the rear-fill speakers. It is also necessary that that h/k or HiFi amps stay in the vehicle to enable the dealer to perform any software updates on the vehicle.
Old May 16, 2011 | 04:46 PM
  #31
redduc's Avatar
redduc
Any idea how this will play with the Alpine system?
Old May 16, 2011 | 05:52 PM
  #32
This kit - 65 41 2 153 318 Alpine hi-fi system retrofit kit?
It would replace it. The Alpine kit is almost the exact same layout as our Soundstage upgrade.
Old May 16, 2011 | 09:36 PM
  #33
veg1515's Avatar
veg1515
Originally Posted by Integral Audio
I'd be happy to, though I have to say that I am always hesitant to answer questions like that since this response will be read by others. Many folks have strong opinions about tweeter materials and those opinions are, for lack of a better phrase, basically wrong.
The tweeter domes will most likely be cloth, but to be honest telling you that doesn't really tell you anything of any value about the tweeter. A lot of folks believe that Aluminum dome tweeters (or metal in general) are overly "bright" (a qualitative term that also is pretty useless) but that isn't true. SOME aluminum tweeters are "bright". The reason is that Aluminum is a pretty good tweeter diaphragm material - lightweight and rigid - yielding efficient tweeters. If those tweeters are low-quality or poorly designed, then you end up with a more efficient low-quality tweeter...one that reproduces inaccurate response at a louder level - you get the idea. On the other hand, lots of folks think or assume that paper is a crappy mid or woofer cone material (it would be more accurate to say they have been mislead to believe paper is crappy by BS marketing). The truth is that paper is still arguably the best composite cone material available - you can do things with paper that you just can't do with other materials. Go to your local high-end home audio store and pull the grilles off of every $10,000+ speaker you can find and note how few AREN'T paper...
The bottom line is that there are almost no hard and fast rules in audio regarding materials, despite what advertisements or the guy at the stereo shop try to tell you. In the end what matters is the quality of three things - the materials, the engineering, and the manufacturing.
I agree
I used to be that guy at the shop
I do know that to my ears ,the tweeter material has a basic sound and i am just curious what was being used
My favorite tweets are the focal be
They are simply magical and without a doubt best tweets i have ever heard but they are spendy and not for everyone due to price and size
My no 2 is the ring radial tweet from vifa (polk uses it in there sr line) i like it for totally different reasons
Cloth tends to have a little bit of what everyone wants in a tweet ,so i think its a good choice for a Product like this
I agree on th paper cone as well paper cones have stood the test of time and other than durability they are tops on most scales
Does ur kit put a 4"in the mid section ?
If so do you use time correction to help with the fact that it is a poor location choice for a 4"?
Maybe new a pillar with tweet and a 3". That would be the butts ***
Any plans for that?
Old May 17, 2011 | 04:14 AM
  #34
daniel4d's Avatar
daniel4d
Still waiting on the delivery of my MCS, but I am looking forward to being able to order the combined kit!
Old Sep 23, 2011 | 04:57 AM
  #35
Purie's Avatar
Purie
Oh just found this thread and very interested.
Any updates yet?
And to my noobness is running audio through the aux input ruin the sound? Is their a better way to run music via my phone with this kit?
Old Sep 24, 2011 | 11:52 AM
  #36
redduc's Avatar
redduc
That's the one. Do you think it's worth it?
Old Sep 24, 2011 | 12:28 PM
  #37
Albiecrazy's Avatar
Albiecrazy
I run my iTouch through the Aux. Sounds great!
Old Sep 26, 2011 | 09:09 AM
  #38
Are you asking if I think the Alpine upgrade is worth it? Or replacing the the Alpine with the Soundstage?
The answer to the first one is "not once our Soundstage is available". The Alpine upgrade doesn't come close to our Soundstage upgrade. It is more expensive, though, so if budget is a driving factor you'd have to make that call yourself.
Old Sep 26, 2011 | 09:23 AM
  #39
Any updates yet?
No firm ETA for the retail Soundstage kits. Still waiting on the wiring harnesses and a few other items. We have been doing local installations of kits (and fabricating the harnesses here), so you should see some additional forum conversation shortly I'm guessing.
Just want to add to Walter's comment a bit. The final sound quality will never be better than the source material. If you are using high bit-rate, purchased (not downloaded) or self-ripped .mp3s then you will generally have good results. If you are using Satellite radio or peer-to-peer downloaded mp3s (which are often remixed or ripped poorly) your audio quality can suffer SIGNIFICANTLY. Additionally, the AUX in is the noisiest input source in the MINI, and that noise level varies from MINI to MINI. Some are relatively noise-free, and some - like Walter's - are so bad they necessitate replacing the head unit.
Old Sep 26, 2011 | 02:55 PM
  #40
redduc's Avatar
redduc
Thanks Kevin. I will mentally prepare to hand you more money
Old Sep 26, 2011 | 06:14 PM
  #41
Purie's Avatar
Purie
Sounds good, I still need to make my order so I have at least 8 weeks to get my car but I will for sure skipped the HK upgrade.
Ya I avoid anything under 128 bitrate and put it to the highest setting if I can. I hope that mine isn't to bad and will keep an eye out for a better solution. I did purchase some CDL tiles, closed cell foam, and some MLV to help with exterior noise, that I'll be adding when I do the install.
Old Sep 30, 2011 | 05:19 AM
  #42
quality_sound's Avatar
quality_sound
The ONLY good thing about the HK setup, and even this is a stretch, is that it comes with the a-pillar mounted tweeters so you don't have to pay for them later. They HK tweeters DO have good extension and are pretty open but the response irregularities, esepcially at higher volues are murder. The HK mids are garbage. The midbasses are really not bad, if you never want to add a sub. They have enough midbass output to make you think they have low bass. Don't get me wrong, they're not accurate in ANY sense of the word, but they are "fun."
Having said all this, knowing the drivers the Soundstage kit is using it'll destroy the HK setup in every sense of the word. The advantage it'll have over the Boost system is so large it's not even worth discussing.
Old Dec 29, 2011 | 07:11 PM
  #43
Nrob's Avatar
Nrob
Just noticed this thread, any update on the Soundstage setup?
Everything I've read sounds great!
Old Dec 31, 2011 | 01:19 PM
  #44
Design, engineering, and testing are completely done. Finishing up the last bits of production details. I had been hoping to get it up on the website by the end of December and shipping in January. Since the end of Dec is coming up in a few hours looks like the website bit won't happen, but January still looks good for purchase availability and shipping.
I'm focused on getting the product perfect and ready, once I've finished that up I'll get more info up here and on integralaudio.com.
If you already know you are interested in the Soundstage, email me at kevin.bennett@integralaudio.com and I will put you on the email list to be notified when they are ready. I will be offering a roughly $250 discount to folks on this list, so definitely email me if you are interested!
Old Dec 31, 2011 | 01:42 PM
  #45
ryan.humphris's Avatar
ryan.humphris
Any Upgrades for the Clubman?
Old Dec 31, 2011 | 01:45 PM
  #46
Yes - the Soundstage will be available for the Clubman, and I am finishing up the design for the Clubman subwoofer system now.
Old Jan 1, 2012 | 02:27 PM
  #47
redduc's Avatar
redduc
email sent.
Old Jan 1, 2012 | 05:49 PM
  #48
Purie's Avatar
Purie
Sweet, email sent as well. Will there be a packaged deal for both the Soundstage and the Subwoofer together? I'll be getting both regardless.
Cheers
Old Jan 1, 2012 | 06:13 PM
  #49
Albiecrazy's Avatar
Albiecrazy
email sent.
Cheers
I don't think you guys will have a better experience as a consumer. Kevin is as good as they come.
Old Jan 4, 2012 | 11:15 AM
  #50
redduc's Avatar
redduc
No doubt. I already have the sub. The kit was really complete and the quality of the sound is superb.
molala
Oct 2, 2015 01:53 PM
Filmy
Sep 7, 2015 08:27 PM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
