Navigation & Audio H K radio problems
Old Jan 26, 2011 | 01:51 AM
fensty245's Avatar
fensty245
H K radio problems
Ive searched but havent come up with my exact problem yet. So lately my Hk radio has been acting up, some days the display acts up, either very bright, kinda lit "blocky" if you know what I mean, and now tonight the display went black and I couldnt adjust volume or change mode/song or anything, and when I shut my car off, it stayed playing. Is this an amp problem or actual headunit issue? Thanks for anyhelp!
Old Jan 26, 2011 | 04:21 AM
daflake's Avatar
daflake
Sounds like a failing HU. I would check EBay as you can get them for fairly cheap.
Old Jan 26, 2011 | 07:08 AM
fensty245's Avatar
fensty245
Sounds good. Hopefully I can get a facelift headunit so then I can play mp3 cd's.
Old Jan 26, 2011 | 07:17 AM
fensty245's Avatar
fensty245
http://cgi.ebay.com/ebaymotors/Mini-...#ht_500wt_1182
Now will that work even though its not an h k unit?
Old Jan 26, 2011 | 08:50 AM
rkw's Avatar
rkw
HK and non-HK use the same headunits.
Old Jan 26, 2011 | 09:20 AM
fensty245's Avatar
fensty245
awesome! thanks! Also the problem is weird, now today i went out and swapped fuses between the two radio spots on the fuse block and now the radio works fine. Would the signs still point to the headunit?
Old Jan 26, 2011 | 11:32 AM
daflake's Avatar
daflake
I would test that for a few more days. Generally you won't get issues like you are describing just because of a fuse.
Old Jan 26, 2011 | 02:42 PM
fensty245's Avatar
fensty245
That's what I thought too. It has acted up before but then went normal, now its doing it again.
slkpsyd
Sep 6, 2015 11:46 AM
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
Herleman
Aug 16, 2015 06:41 PM
veevsato
Aug 5, 2015 04:42 AM
