Navigation & Audio NEW MINI GPS Mount
Old Mar 12, 2010 | 12:55 PM
  #51
TomLINY's Avatar
TomLINY
Are there connections other than power through the mini USB connector? Is that why they say it can't be installed on cars that have SA-609 Nav.? I'd like to have both. A portable Nav that I can walk and boat with, as well as charge in my car. Most of the time in the car I'd leave it showing engine temp after the Garmin wireless OBD sender is released later this month.
Old Mar 12, 2010 | 01:17 PM
  #52
slimjimtell's Avatar
slimjimtell
If you removed the wiring on the mount...easy to do. Run your OWN car charger that came with the NUVI and...BING it works with the NAV.
I have pics and will post here in a little bit.
Old Mar 12, 2010 | 05:40 PM
  #53
slimjimtell
Install complete. very easy to do.
I have NUVI 660 and I ended up using the USB conection that came with the mount. It plugs in backwards but I'm OK with it and it works for me. YES, the steering wheel blocks a little, but not enough for me to worry about.
There are 5 positions
9 oclock position...a little blocked
11 oclock position... not bad
12 oclock position...right in your face full view.
1 oclock position...same as 11 oclock
3 oclock position...a little blocked
I did drill out the silver pins so the arm swings from one side of the tach to the other. otherwise you have 2 positions. (see pic below)
The mount works really good and seems to NOT block the tach with a widescreen NUVI.
Now, do you get some steering wheel block?...YES. I think you would with the NON widescreen as well.
The swing arm works really well and holds well in each position.
Here is the mount without the GPS
9 oclock
11 Oclock
12 oclock
1 oclock
3 Oclock
Old Mar 12, 2010 | 06:56 PM
  #54
jcauseyfd's Avatar
jcauseyfd
11 Oclock
1 oclock
Some block??? Looks like half the screen is covered to me. Maybe just an optical illusion from taking a picture versus looking at it in real life?
Old Mar 13, 2010 | 05:40 AM
  #55
TomLINY's Avatar
TomLINY
If one uses their own charger, it'll only charge while the ignition is on, right? Will the MINI wiring allow the Nav to turn on/off with the ignition, but charge 24/7?
Old Mar 13, 2010 | 01:15 PM
  #56
slimjimtell
it turns on/off with the ignition. It does NOT charge 24/7
If you removed the wiring and threaded your OWN charger which is very easilly doable, you can hard wire your charger cable into the fuse box to power on as you wish.
Old Mar 14, 2010 | 12:10 PM
  #57
Xeraux's Avatar
Xeraux
That's how it is for me, but I can't get a good picture of it. I can see my Nuvi 255 just fine in all of the indented positions. 9:00, 11:00, 12:00, 1:00, & 3:00.
I can see it the best in the 9:00 and 12:00 positions.
It does not charge the Nuvi 24/7, but... Why would someone want/need it to?
It's going to be hooked up to the power when you're driving, right? Do folks use theirs very much on battery power?
Old Mar 14, 2010 | 12:14 PM
  #58
Xeraux's Avatar
Xeraux
Yup.
Originally Posted by Xeraux
I'm going to have to make one little modification. At the top of the main dial, you can see two little rivets. They're preventing the "arm" from swinging all the way around. I'm going to grind those out before getting it installed.
Old Mar 15, 2010 | 06:29 AM
  #59
TomLINY's Avatar
TomLINY
For most users, you're right. I however, am always the exception to the rule. I have the factory Nav, so I'm looking at the portable for different reasons. Mainly the OBD data display, but also for hiking, boating, preprogramming prior to use, geocaching, etc.
I'm very torn about putting a theft target into my car, and for that reason alone will probably stay away from any aftermarket Nav. I've had too many cars broken into, one even had a "hidden" cd changer with a display that I locked in the glove box 99% of the time. When I left the car at the dealer the night before a service, it was broken into with tons of damage. I've seen 5 gps units in one single issues of a nearby community's "police briefs".
I don't want to have to hide a gps everytime I park my car, yet I want GPS to be always available for surprise needs, and to simply monitor my environment. That's why I love the factory Nav.
Old Mar 15, 2010 | 06:11 PM
  #60
jcauseyfd's Avatar
jcauseyfd
For the time that I've had my Nuvi running on battery power (usually when loading routes, but tried it one time in my wife's minivan), the charge runs out very quickly. Probably less than an hour. So using something like a Nuvi that would fit in these brackets would probably be a poor choice for walkable unit. I'd look instead at some of the gps units that are built specifically to be operated while handheld on battery power.
Old Mar 18, 2010 | 10:18 AM
  #61
TomLINY's Avatar
TomLINY
You're probably right about a dedicated portable. But wow, soon I'll be driving with 4 gps units: Factory Nav in dash, Garmin with MINI mount showing OBD data, portable GPS for hiking and boating when I get to my destination, and the unused GPS that's built into my phone!
Old Mar 25, 2010 | 07:24 AM
  #62
thejokell's Avatar
thejokell
So has anyone tried this thing out with a TomTom yet? I haven't been able to get my hands on the second adapter, not sure if Xeraux sent it to me yet. But has anyone else taken the plunge to try it?
Old Aug 19, 2010 | 07:46 PM
  #63
bettehead's Avatar
bettehead
Just ordered a Flexpod mount from CravenSpeed
Although the MINI mount looks nice, I have the wider NUVI and I think it'll mostly be obstructed by the steering wheel.
I opted for the Flexpod mount from CravenSpeed. Pricey at $85, but they do have a Flexpod "Fixie" which is only $55 but has less versatility in positioning. I liked the $85 Flexpod because it can be positioned multiple ways. Fingers crossed! Thanks for the discussion here. As always, I learn a lot from these posts.
Old Aug 20, 2010 | 12:05 AM
  #64
sh944's Avatar
sh944
I purchased the factory Garmin bracket from my local dealership. I installed it myself, its straightforward if you've got some experience with extracting pins out of electrical connectors and reading tech oriented wiring diagrams (as opposed to stuff geared more toward consumers that tend to provide more details and break things down into a step by step process). Its not a job I'd recommend for a novice tho. If your experience is limited to oil changes and basic maintenance, let the dealership do the work. The book time on the installation (and this comes straight off the factory supplied installation sheets) is .5 hr, so don't let them charge you too much.
As far as adapting it for other uses, its not impossible but I'd check out the pin configuration on the USB plug for the device you want to use. Garmin uses a 17.3k ohm resistor on the x pin to ground it to pin 4, which is not a typical configuration for most other USB plugs (which use a 200k ohm resistor) and so I am not 100% convinced it will work on tomtom devices without some help (I don't have one and so I haven't tried it). There is more "magic" going on with the factory Garmin harness than just delivering 5v on pin 1 and ground on pin 4, so proceed with caution, or you might damage both your peripheral device and your car.
Lastly, the bracket itself was a missed opportunity from the factory, imo. It puts the GPS too close to the steering wheel and blocks the view of some of the screen. Its still usable and has a "factory look" to it, but if they had designed it to sit back closer to the dash, you would have had a better and complete view of the screen through the steering wheel and it would have been tucked away nicely so it wasn't terrible obvious from outside the car. I am assuming they designed it the way they did so that you could touch the screen without removing your hands from the steering wheel, but you really shouldn't be doing that when you drive anyway!
I paid $116 for the bracket, if anyone was wondering about the cost. Its overpriced if you were just getting a bracket but the wiring harness/electronics is what makes it worthwhile (assuming you are using a Garmin anyway).
Old Aug 20, 2010 | 11:15 AM
  #65
CravenSpeed's Avatar
CravenSpeed
Vendor
The $85 Kit also comes with a hidden socket so you can power your GPS constantly without wires running all over the car, and it leaves the power socket in the MINI still open for other devices.
The Fixie Kit is a great deal at $55.
Old Aug 20, 2010 | 04:37 PM
  #66
bettehead's Avatar
bettehead
^ Yes, I saw the hidden socket, kellen. I doubt I'll go that route, but it's nice to know that I can at a later date. The only reason I didn't go with the Fixie is because I wanted more flexibility with the unit's positioning. For the $30 difference, I didn't want to be "locked into" a fixed position either left or right of the steering wheel. I do like the "outside the steering wheel" position, though. Right now I have a really nice cupholder mount which is fine, except I had a friend visiting from out of town and needed the second cupholder. LOL!
Old Aug 20, 2010 | 04:55 PM
  #67
CravenSpeed
Vendor
I was just getting the word out. Thanks for your support!
Old Aug 20, 2010 | 05:01 PM
  #68
bettehead's Avatar
bettehead
^ Ah! I see. *laughs*
I'll post my impressions of the mount when I receive it but from the photos on the CravenSpeed website, I really like its versatility and "finished" look. I really didn't want anything too obtrusive, as I don't use the GPS every day. There sure are a lot of goodies on that site! How tempting! LOL!
Old Aug 27, 2010 | 08:10 PM
  #69
t0m's Avatar
t0m
I installed the factory Garmin mount a few weeks ago after buying it from the local dealer, and I agree with most of sh944's comments about the mount and the install process.
One thing I will add is that I still prefer the original factory bracket for the R56, even though it was not adjustable. The new bracket places the GPS too far forward for my taste. So if you can still find the old kit, its worth considering.
The value in the factory kit is definitly in the wiring harness, and the fact that it integrates cleanly into the oem wiring. I'm paranoid about solutions like the hidden socket because it looks like it relies on wire splices. I had a very bad experience with a 1982 Citation, wire splices, and a car fire.... But it did make for an exciting evening roasting marshmallows.
Old Aug 28, 2010 | 09:21 AM
  #70
MINIdave's Avatar
MINIdave
I built my own....I really like the look of the factory MINI mount that people are installing in this thread (thanks for the installed pics, BTW) but after looking at where the unit winds up, and the fact that my new Nuvi is even wider at 5", I decided to do my own fixed mount. This way it's right where I want it and I can see the whole screen - it's also easy for me to enter info or change screens with my left hand, and I felt the right of the wheel mounting blocks my view forward, whereas in the left corner like this it really doesn't.
Here are a couple of pics. I'm still debating whether to paint it or leave it brushed aluminum.
Old Aug 28, 2010 | 11:52 PM
  #71
TomLINY's Avatar
TomLINY
That is beautiful work! The word that comes to mind is awesome. I drove from St. Louis through Kansas City on my way to Denver for M.T.T.S. and would have enjoyed seeing your car "up close".
Old Aug 29, 2010 | 10:30 AM
  #72
bettehead's Avatar
bettehead
I installed my CravenSpeed FlexPod mount yesterday. NIIICCE! I like it a lot. Very factory-like, yet unobtrusive. Small and light but stable. I took pix; I'll try to post one, but I've never done it before so here goes!
Old Aug 29, 2010 | 10:57 AM
  #73
bettehead's Avatar
bettehead
Love My Flexpod!!!!!!!!!!!!!!!!!!!!
Hi again. Here goes my attempt at posting photos.
This is the CravenSpeed FlexPod Garmin Nuvi mount for a 2009 MINI Cooper S. I didn't do anything with hard wiring my Nuvi (I have a Nuvi 880--LOVE IT! It accepts voice commands so you never have to even touch the unit), but the wiring stuff does come with the package. Best of all, I could choose the positioning of the unit, which is the benefit in my opinion of the FlexPod over the Fixie. Some of my pix were taken after dark, as I finished a bit late. Truth be told: I lost a *@&! screw and wasted a lot of time looking for it. Finally I used one that I had, which was silver, and later just touched it with flat black paint to make it blend in. In the below pix, you'll see the screw attaching the mount once in silver and later painted. Also, I like to leave the Nuvi mounting dock in-place and just take the unit with me. The dock removes easily from the ball/socket attachment, though.
Attached Thumbnails NEW MINI GPS Mount-img_8164.jpg   NEW MINI GPS Mount-img_8139.jpg   NEW MINI GPS Mount-img_8149.jpg
Old Aug 29, 2010 | 05:06 PM
  #74
mrwonder's Avatar
mrwonder
I also have the Flexpod and like it, especially the potential to add a gauge down the road with an extension arm. However, I also want to hard wire the GPS without splicing. Does anyone know if the OEM harness kit is sold separately without the mount?
Old Aug 30, 2010 | 06:53 AM
  #75
jcauseyfd's Avatar
jcauseyfd
For those worried about splicing, which part are you worried about? That you have to splice into one of the MINI's wires? Or your GPS cable?
The hardwire itself can be wired into the fusebox using one of the add a fuse things that let's you add an extra fuse socket. So no need to splice an actual MINI wire.
The add a fuse does have to be connected to something - in my case I bought a power cable with bare ends to solder together. That was because I did not want to splice into the Garmin supplied power cord as I occassionally move the unit to a different vehicle.
