Navigation & Audio Itouch keeps turning off
Old Feb 19, 2010 | 06:33 PM
slimjimtell's Avatar
slimjimtell
I have a 2010 MCCS with the Harman Kardon system
I have a 1st Gen Itouch
The Itouch will just disconnect from playing. It shows "Not Connected"
I have jiggled all of the contacts on the cable and it will not disconnect this way.
Although it will play for a while then all of a sudden show "Not Connected"
Any thoughts?
Old Feb 19, 2010 | 07:00 PM
Kimbo80's Avatar
Kimbo80
https://www.northamericanmotoring.co...ml#post2979647
Unfortunately, the MINI Y cable provided by the dealer was not meant to be used with a iTouch, iPhone or 4th gen Nano. It's a voltage issue. I bought this item on for 16.80 on Ebay called the Scoche Passport, and now I don't have any issues. By the way I have a 3rd gen iTouch
http://cgi.ebay.com/Scosche-IFWA-pas...#ht_1825wt_958.
Old Feb 20, 2010 | 07:32 PM
slimjimtell
I have a 1st Gen Itouch. Looks like these are for 2nd Gen up.
I don't think it has anything to do with charging. It plays fine and then will turn off the music and go to the home screen on the Itouch.
on the MINI stereo display it shows, "Not Connected"
Will this part work for me??
Old Feb 20, 2010 | 08:17 PM
adude007's Avatar
adude007
I have an 09 1st gen itouch and I get that blasted Not Connected Error from time to time. The worst is that is says it and before it goes back to the tuner, I can hit the audio button and turn the itouch back on. All without touching any wires.
This happened very frequently when I was running a USB cable into the arm rest. I think its possible that I used a USB cable that was too long or to thin on the wiring. When I stopped using the USB extension this happens much less frequently.
If that adapter does fix this problem on a gen 1 itouch I would buy it in two shakes of a lambs tail.
Casrio
Apr 20, 2021 01:52 AM
rob&JCW
Feb 21, 2018 02:41 PM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
Suspension Products
Sep 2, 2015 10:32 AM
