Navigation & Audio Satelite Radio for o6 cooper s
Im new to the forum
What do i need to get done if i want Satelite radio in my 06 s It has the upgraded speakers but no cd changer. can find the Aux port on the fron of the radio. Do i need a complete new radio/Cd player build in ?
You don't need a new radio. Get a Blitzsafe adapter, an XM direct box & play it through your current radio.
http://www.myradiostore.com/xm-radio...ni-cooper.html
If you already have a sat radio that needs to plug into a jack, you can add the jack.
http://www.outmotoring.com/mini-coop...pod_mp3_hookup
This is for XM. For Sirius there is a box you can buy from MINI. Your current radio is satellite ready.
Satellite Radio Package
2003-2006 Mini Cooper/Cooper S
2005-2008 Mini Cooper/Cooper S Cabrio
Our XM Direct lets you use your factory radio display and controls to listen to XM with no need for a separate receiver mounted on your dash.
Thanks for the Input. But how would i control the XM radio my Radio has only 2 functions Cd and radio. Perhaps i stupid but is i buy this thing and plug it up it is controlled how? Will there apear a third option on the MOD button ?
When I power up my radio is says Sirius. As you've said there is AM-FM CD & Aux plus the Sirius.
Here is a link to a whole lot of info about the Blitzsafe XM Direct install. Unfortunately the pictures are now gone.
Start reading here>>>>> https://www.northamericanmotoring.com/forums/navigation-and-audio/31985-xm-direct-install-for-150-a.html
That is what i asked i don't see the aux or the sirius option i believe that the radio unit can not do anyithig else then FM?AM and CD
If you buy the Blitsafe XM direct & hook it up it will work. Read the thread I linked it will help you understand.
Same here....it sounds great, is a clean factory style install, no second display or controler. The only minus is the limited display on the MINI head.
Once you plug it in, it will recognize it.
I have the factory Sirius unit (DIY installed though, very easy!). It becomes another "mode" you scroll through once it is installed. AM/FM/CD/SIRIUS is the order, I believe. It wouldn't make much sense for it to show up before it was installed...
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
