Navigation & Audio iPhone 3G and iPod/USB charging issue solved!!!
Old Mar 7, 2009 | 02:53 PM
Corey986's Avatar
Corey986
Ok I can confirm that the issue is related to the power draw available on the USB port. When you use the mini cable it draws enough for the interface to prevent charging. When you use an iPhone cable it charges, but slowly due to the 100ma provided by the interface.
Since the iPhone draws different amount of power depending upon the situation there may be cases where your in edge mode sitting idle and what the mini cable provides will eventually charge over a long period of time.
My solution, suplimemt the USB power provided with off the shelf stuff.
For about 15 bucks I got a USB car charger which provides 500ma (it also includes a spare house charger), I then used a USB extension cable made specifically for a USB wifi/3g modem which has 2 plugs. It's exact purpose is to allow the modem to pull power from 2 USB ports. I then plug one into the car USB and one into lighter USB charger and then plug the mini cable into the cable's jack for the modem. My iphone should be getting about 600ma or about the same as a house charger.
My iPhone charges all the time now and charges fast.
Old Apr 22, 2009 | 07:35 AM
chmurph2's Avatar
chmurph2
Model specifics?
Corey986,
Thanks for posting that you solved this. Can you please specify the model you got for the USB charger and the extension cable? Bonus would be a link to them on Amazon, or wherever?
Thanks,
Chris
Old Apr 24, 2009 | 08:52 AM
njchris's Avatar
njchris
Where did you get that USB wifi/3g modem cable?
Old Jul 2, 2009 | 06:48 PM
bjlovet's Avatar
bjlovet
To anyone still looking for this, I found the cable at Amazon here:
http://www.amazon.com/USB-Power-Adapter-Y-Cable/dp/B000JIOHDE
There are several USB / lighter adapters to choose from. The one I chose is this:
http://www.amazon.com/Belkin-Dual-Charger-iPod-Black/dp/B001FB578I/ref=sr_1_4?ie=UTF8&s=electronics&qid=1246585663&sr =1-4
I hope this helps someone.
Old Jul 2, 2009 | 09:25 PM
robovega's Avatar
robovega
First off, thanks Corey986 for sharing your workaround. Much appreciated.
I really like this solution, but I'm reluctant because of the messy look of excess cable and adapters. According to eBay, the cable from Amazon is 3.28 feet.
This seems to be another option from eBay:
New USB Female to 2 USB A Male Power Y Cable Extension
This cable measures only 11 inches, so this could make things a little more tidy. I'm also eyeing this power adapter that sits flush against the cigarette lighter socket:
Belkin Micro Auto Charger
Just thought I'd add a few more options for those motorers who want to try and keep things neat.
Old Jul 3, 2009 | 09:51 PM
redrobin's Avatar
redrobin
Anyone know if this works for the 3gs as well?
Old Jul 7, 2009 | 07:33 PM
chmurph2's Avatar
chmurph2
+1 Anyone know if this works for the 3gs as well?
Old Jul 20, 2009 | 05:56 AM
Little Bean's Avatar
Little Bean
Would love to know the final outcome of Iphone 3gs charging in 09 Mini's. Don't want a cigarette plug adapter otherwise loose my radar detector. What to do? Anyone know if the new 3gs will work through bluetooth for music in the cars?
Old Jul 20, 2009 | 08:43 AM
schatzy62's Avatar
schatzy62
Bluetooth in most cars is only for phone use music is NOT handled by bluetooth in MINI or BMW's
Old Aug 12, 2009 | 10:13 AM
markusw's Avatar
markusw
Corey986, Thanks for solving this problem!
I ordered that cable from ebay and it charges the 3gs! Sadly, the iPhone still gives me the annoying airplane mode nag screen .
Old Aug 12, 2009 | 11:12 AM
chowgregory's Avatar
chowgregory
I bought my new clubman last month and trying to play music from iPhone 3G S, but it is not working. It keeps saying "this accessory is not made for iPhone". I don't know what's going on. Dose anybody know why?
Forgot to tell I use Y cable that come with the car.
Old Aug 12, 2009 | 11:37 AM
markusw's Avatar
markusw
  1. Plug it in and ignore the "this accessory is not made for iPhone" message.
  2. Press the audio button on the car's radio and it should give you the choice of Tuner, CD, and IPOD. (if ipod doesn't show up, something isn't plugged in)
  3. Select IPOD and the car will go into the ipod menu (and start playing music).
  4. Select the song you want to play.
Old Aug 12, 2009 | 11:40 AM
chowgregory
Thank...I will try that.
Old Aug 12, 2009 | 11:42 AM
markusw's Avatar
markusw
If it brings up the airplane mode message, just select "No"
Old Aug 12, 2009 | 01:10 PM
chowgregory
I just tried, but it still doesn't work. It doesn't even show iPod.
Old Aug 12, 2009 | 01:13 PM
chowgregory
I just tried, but it's still not working. It didn't even show the iPod. I don't know if it is my iPhone problems or the car problems.
Old Aug 12, 2009 | 01:20 PM
markusw's Avatar
markusw
What options did it show you when you pressed the Audio button on the car's Radio?
Old Aug 12, 2009 | 01:27 PM
chowgregory
It shows Tuner/CD/USB/AUX
When I plugged in iPhone, the USB showed empty.
Old Aug 12, 2009 | 01:41 PM
schatzy62's Avatar
schatzy62
Without the iPhone connected pressing the audio button should show
TUNER - CD - USB - AUX
When you plug in the iPhone it should change to
TUNER - CD - IPOD
If this does not happen what does the screen say, is it
TUNER - CD - USB (with AUX no longer displayed)
If that is the case then it is probably a setting in you iPhone. Sound like it is set up for MASS STORAGE and is thus being recognized as a hard drive not an iPhone/iPod.
it could also be a problem with the MINI "Y-Cable".
Also when testing it make sure it is fully charged so that a charging problem does no mess things up either.
Old Aug 12, 2009 | 01:52 PM
chowgregory
TUNER - CD - IPOD
What's the setting for iPhone?
I have tried so many things but none of them worked.
Old Aug 12, 2009 | 02:03 PM
schatzy62's Avatar
schatzy62
Not sure what you mean "What's the setting for iPhone?"
Do you mean the cars setting or some setting on the phone itself?
Old Aug 12, 2009 | 02:06 PM
chowgregory
I mean something setting on the phone.
Old Aug 13, 2009 | 05:43 AM
schatzy62's Avatar
schatzy62
Plug the phone into your computer and start iTunes. Check to make sure the that the phone is not set for "MASS STORAGE" then try again.
Old Aug 14, 2009 | 06:10 AM
chowgregory
I don't think my phone is set for mass storage, but I did check it form iTunes. It did not show it is mass storage. However, I tried my iPod last night. I realized it is not working either. It's same thing like the phone. Maybe the "Y" cable or radio has problems......
Old Aug 14, 2009 | 07:58 AM
schatzy62's Avatar
schatzy62
Try this then. Use the cable that came with your iPod and plug that into teh MINI USB port and the other end into you iPod (not iPhone)
You should then be able to select the USB ooption onthe radio and at least see and play something.
If this can be done then most likely the "Y-Cable" is bad.
