Navigation & Audio iPhone Stopped Working
Old Nov 23, 2008 | 05:59 PM
Jaycooper's Avatar
Jaycooper
My iPhone suddenly stopped working in my MCS. I was listening to the iPod function, made a bluetooth call, and in the middle of the call the signal dropped and I could not get the iPod to play. The phone works fine as does the iPod function if neither are used in conjunction with the car. The cable connecting the phone to the car is intact and plugged in. The bluetooth function is turned on. I can't figure it out. Does anyone have advice?
Old Nov 23, 2008 | 06:20 PM
russgriz's Avatar
russgriz
I had a problem where I could no longer pick the iPhone with the "Audio" button. Instead of "iPod" it said "USB" and when I picked that, it would say "Loading" but not work. I was experimenting with various iPod/iPhone cables to see which would work at the time, but once the problem started, even the original cable didn't work. After much screwing around, I gave up. I had tried turning everything off in the car, resetting the iPhone, etc. without luck. The next morning the iPhone worked fine using the cable that came with it. I stick with the original cable now and no problems since. Hopefully your problem (if yours was the same as mine, I could not tel for sure from your post) will clear up in the morning. Not much help I know but I guess what I'm saying is that your problem might be a fluke like mine and might clear itself if you give it time. Keep us posted.
Old Nov 23, 2008 | 07:12 PM
desertmini21's Avatar
desertmini21
Have you tried to:
1) push the button on the top of the phone until the phone powers down then power it back up
2) play the iPhone with headphones
3) connected your iPhone to your computer and and reinstalled the software?
Old Nov 23, 2008 | 07:17 PM
Jaycooper's Avatar
Jaycooper
I've tried everything except re-installing the software. In fact, I'm not quite sure what software I would work on. If it is the MINI software, how would I access it? Thanks
Old Nov 23, 2008 | 07:24 PM
desertmini21
The software you might need to reinstall is the iPhone 2.2 software.
1) You connect the iPhone to your computer via the USB cord,
2) iTunes should open
3) click on your iPhone in iTunes
4) This is where it gets a bit fuzzy from memory, but there will be several tabs. One of them will give you the option to reinstall the software.
Apple just released 2.2 a couple days ago. You will need to install it anyway.
Did you say that you cannot listen to the iPod application through the iPhone speakers as well?
Old Nov 23, 2008 | 11:27 PM
Robin Casady's Avatar
Robin Casady
The tab is "Summary". Click the "Check for Update" button.
There is also a "Restore" button that will restore factory settings, and I believe, reinstall the iPhone OS. Do this if the update doesn't fix the problem.
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Phantogram
Aug 12, 2015 12:11 PM
tippin
Aug 5, 2015 08:43 AM
