Navigation & Audio iPhone 3G owners BEWARE!
Old Nov 19, 2008 | 07:07 AM
  #26
Apple's Avatar
Apple
Originally Posted by daflake
Why? It is not their fault that Apple changed it and it was a known change. You had a choice to buy an Iphone, why should MINI have to pay for your choice?
Agreed buy a charger!
Old Nov 19, 2008 | 07:13 AM
  #27
RaceTripper's Avatar
RaceTripper
I could swallow that rationale a little easier if they didn't charge $100 for a $10 cable.
Old Nov 19, 2008 | 08:49 AM
  #28
desertmini21's Avatar
desertmini21
The cable MINI provided for us was made specifically for the iPod/iPhone, correct?
Old Nov 19, 2008 | 12:32 PM
  #29
meb's Avatar
meb
Apparently so...
...my iPod adapter was charging my itouch, but this adapter worked only for one week, then cut on and off for the second week and now nothing...the Aux does not work either...I have the HK stereo. Very frustrating since I would rather use the Aux and have the functions of the iTouch.
Old Nov 19, 2008 | 06:20 PM
  #30
mielnicki's Avatar
mielnicki
I just got an iPhone 3g, not really upset that it doesn't work with the 1st gen MINI iPod adapter in my '05, I have a 5th Gen iPod for that.
But I find it very funny, that 90% of the posts in this thread are from 2nd Gen MINI owners posting in the wrong thread!
Old Nov 19, 2008 | 06:39 PM
  #31
RaceTripper
Why, what's the big deal? The issue isn't different for 2nd gen. MINIs.
Old Nov 19, 2008 | 07:28 PM
  #32
desertmini21
Come on boys, focus...at least MINI will have a fix for this issue in January.
Old Nov 19, 2008 | 07:31 PM
  #33
mielnicki's Avatar
mielnicki
Correct the issue is the same, however the forum you would post your issues and findings in would be different based on the audience reading the posts.
The 2nd Gen MINI adapter has the potential of being upgraded by MINI, not necessarily free.
The 1st Gen MINI adapter more than likely can not and will not ever have a "fix"
Old Nov 19, 2008 | 07:32 PM
  #34
mielnicki's Avatar
mielnicki
Not likely for the 1st Gen MINI iPod adapter.
Old Nov 19, 2008 | 08:18 PM
  #35
daflake's Avatar
daflake
You don't have to buy it...
Sorry, but even if the original was for the Iphone, it does not say Iphone 3G Apple CLEARLY stated then were getting away from Firewire charging. I knew this before I bought the device and was told about it openly at ATT and Apple. So it is no surpirse and I can't see how Apple, ATT or MINI owe any of you a thing. There are adapters that work for about 30 bucks.
Old Nov 20, 2008 | 01:44 AM
  #36
johnf36's Avatar
johnf36
Okay so am I missing something here Scosche claims this works.
http://scosche.com/products/sfID1/21...productID/1667
Okay this thing does not work with cables that have USB cables. May Ipod system uses a PS/2(firewire) plug . Is this the difference. Because Scosche does sell a cable with a USB end for this problem.
http://scosche.com/products/sfID1/21...productID/1598
I am only guessing here but are we dealing with 2 different plugs and 2 different gens of Mini's?
John
Old Nov 20, 2008 | 10:27 AM
  #37
johnf36's Avatar
johnf36
So is this the same thing as the Scosche
http://cablejive.com/iphone_3g_charge_converter.html
http:///www.youtube.com/watch?fs=1&v=S1pf3fH9_hI
Old Nov 28, 2008 | 07:01 PM
  #38
schulzmc's Avatar
schulzmc
Originally Posted by johnf36
I bought the converter from cablejive. It came today and works flawlessly. Finally, I can play my tunes on the iPhone AND charge it.
Old Nov 28, 2008 | 07:30 PM
  #39
djdub's Avatar
djdub
Scosche didn't work for me on my 09.
The Cablejive looks just like the Ridax adapter with the mini-USB plug on the side of it. The Ridax didn't work for me.
I've found that plugging it in with the door open works fine for me until they come out with the new cable.
Old Nov 28, 2008 | 08:03 PM
  #40
johnf36's Avatar
johnf36
Thanks Schulzmc.
Djdub I believe none of them will fix your 09's problem. I believe something else is going on with your installation. Good Luck.
John
Old Nov 29, 2008 | 03:52 PM
  #41
shokk's Avatar
shokk
7th Gear
Anyone using this with an 07?
Old Jan 2, 2009 | 12:50 PM
  #42
Ochickenboy's Avatar
Ochickenboy
adapter works (almost as advertised)
The Schoche Passport works (almost as advertised) for me. I saw this thread, but decided to try it anyway. When I plugged it in to my '05 Cooper S I got the warning that the device was not made to work with the iPhone (I have the 3G version) so I figured this thread was right. I would have sent it back, but I forgot to charge my phone that night and out of desperation needed it to charge the next morning in my car. Turns out it works perfectly, I just have to press "No" when the error screen pops up. It charged my iPhone even though it was nearly all out of juice and also works with my daughter's new Nano. Don't know if it works on newer Coopers, but it works on my '05.
Old Jan 15, 2009 | 08:44 PM
  #43
Motor On's Avatar
Motor On
Bump. Did this work for anyone else as well?
Old Jan 16, 2009 | 08:32 AM
  #44
stevehy's Avatar
stevehy
08 Cabrio S (1st gen), adapter works perfectly with 3G iPhone. No need to manually dismiss messages, they will disappear on their own.
Steve
Old Jan 27, 2009 | 03:51 PM
  #45
MLPearson79's Avatar
MLPearson79
I just ordered a Scosche Passport. I can't get my 3G to charge using the OEM adapter no matter what I do (door trick, level of charge the phone already has, etc). Hopefully it works!
Old Jan 27, 2009 | 04:17 PM
  #46
OctaneGuy's Avatar
OctaneGuy
I'm the new owner of a iPhone 3G 16gb unlocked model (Italy) and love it! This thread would be soooo much more useful if there was a summary between gens. Maybe people could simply add the phrase 1stgen or 2ndgen or 05MINI or 09MINI to the end of their post when they post whether an adaptor workds or not. Just a suggestion.
It seems that the Cable Jive and Scosche adaptors solve the power issue for 1st gen owners and not for 2nd gens. Right now, the Scosche adaptor is sold out until February, so looks like I will order the Cable Jive right now.....whoa...just checked the Cable Jive--$20 for USPS--must be not in the USA---$54 for the Cable Jive...I'll look for another Scosche retailer, lol...which turns out is as close as the Apple store...woohoo.
Richard
Old Feb 4, 2009 | 12:58 AM
  #47
MLPearson79
I got mine on eBay for $22.50, shipped. Tried it out today, works like a charm!
I need to do some more cupholder modification though, to make it fit now!
Old Feb 4, 2009 | 04:12 AM
  #48
johnf36's Avatar
johnf36
Don't forget this one is out there too
http://www.chargeconverter.com/shop/...m?connipod.htm
John
Old Feb 7, 2009 | 10:21 AM
  #49
ellinara's Avatar
ellinara
This is what I did I bought a car charger for 10.00$ then I used an audio cable .99 cents and that solved it . BTW I did not opt for the iPod jack.
Old Feb 7, 2009 | 12:39 PM
  #50
OctaneGuy's Avatar
OctaneGuy
Got my iPhone 3G working along with the Scosche adapter. Nice to know that the iPod adaptor can be installed at the same time as the AUX in for my Garmin.
