Navigation & Audio Installed the KUDA mount with Garmin nüvi 760
Here you go plus I added that thread to my favorites for future reference.
Link: https://www.northamericanmotoring.co...=110837&page=3
Here is JudgeS single post from there too.
Link: https://www.northamericanmotoring.co...3&postcount=51
Jim that is okay and not to worry as it works fine.
Now regarding which screws,I first drilled small holes through the Kuda mount using the adaptor as a template then I used the 4 screws,4 washers and 4 nuts to anchor it to the mount.
I hope that helps.
I hope that helps.
Jim
I hope that helps.
I hope that helps.
You have the same adapter that I have so I have a question. It looks like it will move from side to side to allow for even better adjustment. I undid the holding screw, but it will only move a little before it hits a stop of some sort. Do you know how to get it to swing either way??
Jim
Jim R. the Kuda arrived today and was installed in less then a minute. Thanks for all the assistance.
Jim
Jim
Jim
Jim
That is excellent to hear and see how easy to install the KUDA mount is doing it that way.
And you are very welcome and I am glad that I could help.
lacning74 answered your other question already but I do see what you mean about it looking like it could swivel from side to side.I did the same thing too when I got mine by undoing the holding screw only to find out it won't.
Jim,
Jim,
Jim
Jim
Is there any (easy) way to to remove the dash insert so that the wires could be hidden behind it? There seems to be room at the corners for the wire itself to come through, but not the connector. I have them running in the grove right now which is OK, but completely hissed would be better.
Jim
This thread may be helpful re: hiding wires
Which of these two mounts do you like better? I dont have a GPS unit, and simply want to mount my Iphone. I dont know that I like it down to the right. How is using your phone there?
squawSkiBum
Oct 2, 2015 09:21 AM
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
