Navigation & Audio My sound system... step by step
Ha, found the thread over there ! Still in French but as most of us prefer the pictures anyways, it might help :P
http://forums.motorlegend.com/vb/showthread.php?t=30057
I am currently installing a system (new front and rear speakers, subwoofer, two amplifiers, and a head unit) in my 2003 R53 and I have followed some of the tips from this install. A couple things are important to note about Colin's method that I have learned from my install so far...
If you plan on using the "rubber snake" to run wire to the doors from the cab you need to make sure you have some time to waste. It took me between 3 and 4 hours to do both doors
. Running the wire through this piece can be frustrating and, as always, lube is important
. Also, in order to clip the "rubber snake" back onto its in-cab adapter piece you have to reach your hand inside a small hole in the cab. There is a large rubber grommet behind the glove box or steering wheel on the door-side of the car. This must be removed. Then you have to stick your hand into the cavity between the interior and exterior of the car to grab the adapter piece. Basically, if you have large hands this is a risky method to try. After doing this my hands look like I have been playing with fully-clawed kittens.
Anyway, I have removed most of the interior pieces (besides the upper dash area) of my car at this point and have learned a lot about installing a stereo in a mini. Feel free to bring this thread back alive and ask me some questions.
. Also, in order to clip the "rubber snake" back onto its in-cab adapter piece you have to reach your hand inside a small hole in the cab. There is a large rubber grommet behind the glove box or steering wheel on the door-side of the car. This must be removed. Then you have to stick your hand into the cavity between the interior and exterior of the car to grab the adapter piece. Basically, if you have large hands this is a risky method to try. After doing this my hands look like I have been playing with fully-clawed kittens.Anyway, I have removed most of the interior pieces (besides the upper dash area) of my car at this point and have learned a lot about installing a stereo in a mini. Feel free to bring this thread back alive and ask me some questions.
Thanks for the feedback, I'm still to scared to start my project.
I really want to put different speakers in the doors but running the cables really scares me.
Running 2 sets of wires is going to be a pita to do. Doing 1 is fine. I did 1 wire only and it was cake then I decided to try 2 wires on the advice of my friend. 45 minutes later and no luck connecting that thing in between the doors was frustrating. Pulled out 1 wire and closed up fine.
I think it's better to have a female or kid help you if you have big hands.
That "rubber snake" is called a boot. What i did is pull the boot off from the door and used a piece of wired coat hanger and taped it to the wire i wanted to plumb. Some wd40 helped a bunch. With that boot popped out, you can pull out the entire boot out some and make it as straight as possible.
The bigger obstacle was that boot in the cab that was killing me.I popped that out so I could put a hole in it and plumb the speaker wire in the cab. It was a pita to pop back in. Big hands, tall guy, and cramped area don't mix.
Yes rcantu, you hit the nail on the head. Snaking the wire through the boot sucks, but re-attaching the boot to the car is the worst part. The good part about getting a single wire snaked is then you can tape your next wire to the midsection of your already snaked wire and just pull it through easy. Using wire lube helps too, I think the stuff I used was called Clear Glide.
To re-attach the boot to the car, I plugged the boot into the open hole, and then crammed my hand in the small opening inside the car behind the second boot/grommet. Working inside the hole I was able to plug the two pieces back together.
Volker, if you want new speakers in the doors you will definitely have to make brackets for them to mount to. Mine were much more primitive than ColinBrussels's were. I basically used a block of wood cut so it would miss the tabs in the door. The block mounted to the original holes, and my new speakers mounted to the block.
i wired my speakers in that same exact way through the factory harness, and dremeled out the un-used part
very clean install for sure, and i have the pioneer 880 HU as well, my favorite unit by FAR..i will never sell it!
Nice system. I like my alpine PDX amp. I got the PDX-5 so I could keep the install simpler and like it running my 12" type S sub so far. I like your amp location. I wonder if I should abandon my false floor install in the boot and just put my box back there and make it bigger and put my amp under the drivers seat.
Sweet work. I did the same thing to get my speaker wires out of the PITA doors.
patsum
26
May 29, 2021 06:29 PM
